Evap system delete?
Well trying to pull my stock fuel lines tonight I pulled on the wrong to and kinked and messed up what I now know are the evap lines. One is simple a vent, the other goes to a solenoid and vacuum source on the throttle body plenum. So can I delete the lines and get rid of the evap system somehow. Emissions do not matter for me in my state. I just don't think replacing the lines would be worth it and also a pita.
Line are 4 and 5. https://cimg1.ibsrv.net/gimg/www.6sp...42a96b7207.gif |
The only downside is possibly* more gas vapor smell.
Originally Posted by 03EvoIII
(Post 4498087)
Originally Posted by flewis763
(Post 4498160)
I think I'm going to run the vent hose all the back to the intercooler exit. Shouldn't have any smell in the cab then
Originally Posted by G-Rat
(Post 4498348)
Watch out for exhaust flames back there.
(Post 4497891)
My advice would be to replace the lines to keep the vapor recovery system functioning properly. This also keeps the pressure in the tank at an optimum level and helps to prevent wasting gasoline through evaporation. The fuel gets quite warm from the pump running full blast to keep those siphon jets feeding fuel from their respective basins to the pump so the hot gasoline is going to generate a lot of vapor. Even after the engine is shut off there will be very likely a goodly amount of gasoline vapor around the car. On a still day or night I hope someone doesn't decide that litter doesn't matter and toss a light match close to your car. |
Originally Posted by Macster
(Post 4498453)
Not sure I agree with your cavalier attitude towards emissions.
My advice would be to replace the lines to keep the vapor recovery system functioning properly. This also keeps the pressure in the tank at an optimum level and helps to prevent wasting gasoline through evaporation. The fuel gets quite warm from the pump running full blast to keep those siphon jets feeding fuel from their respective basins to the pump so the hot gasoline is going to generate a lot of vapor. Even after the engine is shut off there will be very likely a goodly amount of gasoline vapor around the car. On a still day or night I hope someone doesn't decide that litter doesn't matter and toss a light match close to your car. I did remove the lines from the kink back, I have now removed the evap system yet though. Evap removal is common among other performance cars, don't see what the large issue would be here. I would install a vent hose with a filter and roll over valve so if you were roll, fuel would not come out the vent tube. All older cars were this way as well. |
