rear spoiler issues
Old Apr 9, 2016 | 06:26 PM
DaveCarrera4S's Avatar
DaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond repute
Originally Posted by rickjaffe
what's the test to see if it's the switches?
Check post #7 - Factory troubleshooting guidelines.
Old Apr 9, 2016 | 08:31 PM
Atrox's Avatar
Atrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud of
You don't need to remove the spoiler to fill/bleed the Rams.
Old Apr 9, 2016 | 11:22 PM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
If you dont want to fix ur pump buy daves amazing system ill happily buy your old pump and rams.
Once your ready to sell pm me
Cheers
Tim
Old Apr 10, 2016 | 11:16 AM
Macster's Avatar
Originally Posted by DaveCarrera4S
1. Better than pulling the fuse and disabling the lid release, light and spoiler, just pull one of the leads to the spoiler electric motor above the fan. Lower the black shroud and it becomes visible. 2. I am that "someone", in fact you and I have corresponded about the electric mechanism before Macster. Post #7.
Yes, you are indeed that "somone". And I recall exchanging some emails with you regarding the Turbo spoiler.
I read post #7 but at the time didn't connect it/you with the electric spoiler kit.
Old Apr 11, 2016 | 10:24 PM
rickjaffe's Avatar
rickjaffe is infamous around these parts
more possibly diagnostic info: shut the car off with the spoiler raised.
took it for a spin today. no problem with the spoiler automatically retracting and no light.
so I'm thinking the down microswitch is ok. is that a mechanically sound assumption?
when I went past 74 the spoiler raised without any problem, but I got the spoiler light. I may have even heard a clicking sound.
so is that diagnostic of a bad up relay, or not enough fluid? or neither?
was trying to figure it out before pulling stuff off, but might not be possible.
Old Apr 11, 2016 | 11:02 PM
techweenie's Avatar
techweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant future
Cheers
Tim
If the OP doesn't want to, I have a set for sale.
Old Apr 11, 2016 | 11:07 PM
Never Enough's Avatar
Never Enough is a glorious beacon of lightNever Enough is a glorious beacon of lightNever Enough is a glorious beacon of lightNever Enough is a glorious beacon of lightNever Enough is a glorious beacon of lightNever Enough is a glorious beacon of light
That just seems to be the way the system is designed to work.
It will usually re-set the warning lights after you shut the car off, and then won't show the warning lights again until about 10 seconds after you reach 74MPH.
Ask me how I know...
The problem could indicate a micro-switch failure, but could also indicate a problem with the hydraulic system, and leaking O-rings seem to be a very common problem. Check for any signs of oil leaks in the black plastic ram bottom covers. If there is any oil there, the problem is likely a leaking ram that will require adding hydraulic fluid, and bleeding out any air from the system.
There are numerous posts on Rennlist that describe this in great detail with photos, and it is widely regarded as a PIA.
Best of luck.
Old Apr 11, 2016 | 11:18 PM
timccloud's Avatar
Ok sweet pm me a price shipped to AU postcode 4300
Old Apr 12, 2016 | 03:52 PM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
You are probably low on fluid. Search my name for my fill up method thread. Easiest out there.
Old Apr 13, 2016 | 06:15 PM
docboy's Avatar
docboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond repute
I called Sunset Porsche today and the spoiler microswitch is on back order! Tech has no idea when this switch will be available, advised me to call in a month to check on its availability.
Anyone know where else to order this part?
Old Apr 13, 2016 | 06:59 PM
XLR82XS's Avatar
Try Pelican parts or WorldPac. I doubt RockAuto would have it but worth a look.
Old Apr 13, 2016 | 08:46 PM
Originally Posted by docboy
I called Sunset Porsche today and the spoiler microswitch is on back order! Tech has no idea when this switch will be available, advised me to call in a month to check on its availability. Anyone know where else to order this part?
must be selling like hot cakes... Haha. One can also order a complete new loom with included microswitches, I believe autoatlanta has them, or your local dealer can probably order it. Shame there are sooooo many weak links with the factory hydraulic system.
djcooper@rennkit.com
rennkit.com
Old Apr 14, 2016 | 12:18 PM
PelicanParts.com's Avatar
PelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond repute
If you have a part number handy I can let you know if we have it and if not a possible ETA on the part.
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Parts | DIY Help | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Old Apr 14, 2016 | 12:24 PM
docboy's Avatar
997-613-167-00
Let me know what you find out, thanks!
Old Apr 14, 2016 | 01:21 PM
997-613-167-00
Our system was showing NLA, but it seems as if it's out of stock possibly nation wide at the moment. No ETA.
