996 Turbo "Track" Stereo
So my 01 turbo came with the stupid Bose and Nav option from the factory but I love the way the GT3 center console delete looks and I won't be driving the car very much/ I'll be doing a few DE days a year. So my question is what bezel do I need to move the Ac control up and put a single Din in? I will also be pulling the OEM AMP, speakers and wires and just run dash/ front door speakers off the decks internal amp. Has anyone done this before and if so do you have any pics of install? Thanks in advance
i have a single din cd23 thats plug and play for the bose fiber optic if that interests you. upper cubby as well
Originally Posted by 32krazy!
(Post 4571748)
Not sure it would work for you, '01 didn't have the fiber optics
no nav but it has bose fiber optics
(Post 4571848)
2003+ is MOST/fibre, -02 is non-fibre
Mine is 2002 and has MOST/fibre. ;)
Its easy to tell. Just look if yu got a glovebox. hilarious |
Originally Posted by rennteche55
My question was asking about deleting all the factory wiring and speakers. If anyone has done it and just replaces it with the 4 speaker system and a head unit. It would be simple, cheap and light.
I did mine that way, 01 total replacement with the gt3 delete, 01 has no fiber optics in it, all wire btw. moved a/c control up and added din mount below it
You have a CDR23? I have never seen a 2002 with MOST.. :confused:
Originally Posted by ghostofpain
(Post 4571858)
Originally Posted by 993GT
(Post 4571905)
stupid question how do you tell you have MOST? |
FWIW, the door speakers/enclosure are significantly heavier than the rear speakers.. The GT2/3 cars don't come with the door speakers if I recall. Maybe just run dash speakers and rear speakers, the OEM speakers in those locations are not very heavy.
Originally Posted by DERBOOST
(Post 4571872)
Good question, being as I did it about 9 years ago.....lol All the power for the stereo is direct from the battery on its own breakers, if I remember correctly I ran a lead from the ignition switch to a couple relays to turn the whole thing on. Pretty sure I used the Gt2/3 bezel frame to move the AC stuff up and made a frame for the din from billet aluminium then wrapped it in carbon.
the upper a/c trim is part number 9965526770001C |
