Clicking noise from rear wheel...
Old Nov 17, 2016 | 08:50 PM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
Anyone had a wheel bearing go out? I'm hearing a clicking noise about every half rotation coming from a wheel hub area at slow speeds.
Old Nov 18, 2016 | 05:31 AM
'02996ttx50's Avatar
i have, it's more of a "growl" that is mitigated by sharp turns in one direction vs another. eg it will subside upon turning meaning the opposite side bearing is going bad.
not a "clicking" sound ( iirc )
Old Nov 18, 2016 | 06:21 AM
joey996tt's Avatar
joey996tt is infamous around these parts
Wheel bearing will be like a non stop growling/humming increasing with speed and when you load weight onto that side of the car..... sounds like your problem might
Be an axle, rock stuck in your tire, backing plate touching
Old Nov 18, 2016 | 07:10 PM
BLKMGK's Avatar
CV click when they go, does it have any play?
Old Nov 19, 2016 | 06:05 PM
r6vr6's Avatar
r6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to all
Most of the time when I hear a clicking it's a screw head sticking out of the tire maybe if I am lucky a big rock in the tread.
Old Nov 20, 2016 | 06:16 AM
32krazy!'s Avatar
have you changed the lugbolts ? i have seen on m/b folks change wheels and add longer lugbolts that stick out the back of the hub and hit the ebrake on rotation.
Old Nov 20, 2016 | 04:33 PM
VGLNTE1's Avatar
Hum....they are aftermarket for the wheels I have I'll have to check that
