Door Lock cable replacement help
Old Jan 21, 2017 | 03:01 PM
xmaciek82x's Avatar
xmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant future
I need to replace the driver side interior door handle cable.
Does any one have any advice on how this cable gets disconnected from the door lock mechanism?
Does the entire lock mechanism need to come out?
I looked up some diy and this is the part I'm having issues disconnecting because the lock mechanism seems to be slightly different in the TT.
http://cdn4.pelicanparts.com/techarticles/Porsche-996-997-Carrera/78-BODY-Door_Locks_and_Handles/images_small/pic05.jpg
Is this the correct part number 99653732003?
Old Jan 21, 2017 | 04:02 PM
32krazy!'s Avatar
if i rememeber correctly it is easier to work with out side the car. i think i have one of those but not sure which side i can look sunday i think my assembly still has the cable attached
Old Jan 21, 2017 | 05:01 PM
xmaciek82x's Avatar
Thanks Steve.
That cable is like $10 surprisingly. I almost had the lock mechanism completely out, I just didn't know how to get the outside door handle unattached from it. Was short on time so didn't really mess with it too much yet.
Do you know if the outside door handle needs to be removed to get it detached from the actual lock mechanism?
Old Jan 21, 2017 | 05:03 PM
32krazy!'s Avatar
Originally Posted by xmaciek82x
Thanks Steve.
its been yrs since i messed with this but i do think i unbolted the outside handle to remove mine.
Old Jan 21, 2017 | 10:25 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
pretty sure you're going to have to pull the latch assembly out to do it, but haven't tried inner cable vs installed in door...
I've got a couple complete doors and also loose door latch assemblies at my shop...actually doing a new door latch assembly on a 996tt this week
