FF1 trans mount inserts with 997 trans mount?
Old Feb 24, 2017 | 07:52 PM
xmaciek82x's Avatar
xmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant futurexmaciek82x has a brilliant future
Is anyone running Function First inserts with the 997 trans mount?
https://www.suncoastparts.com/product/FF199XTM.html
I think it is time to replace the original 996 trans mount and not sure if I should go with 997 mount only, 997 mount with the FF1 insert, or go with Torque Solution Street inserts.
Old Feb 24, 2017 | 08:37 PM
Aktavate's Avatar
Aktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of light
I'm using the yellow 70A inserts with a 997 mount and I love the way it shifts. Did both at the same time though so cant comment on the difference the insert makes.
Old Feb 28, 2017 | 07:34 PM
xmaciek82x's Avatar
Thanks Aktavate. You running semi solid engine mounts?
Also, any other feedback?
Old Mar 2, 2017 | 02:30 AM
Aktavate's Avatar
No still stock mounts for me.
