How to remove FIXED INTAKE without removing ENGINE
Old Apr 30, 2017 | 11:22 AM
OK51MON's Avatar
OK51MON is infamous around these parts
Lightbulb How to remove FIXED INTAKE without removing ENGINE
Im currently doing my fender intakes on the car.
Can anyone direct me to a guide as to how I can remove the fixed intake across the back of the engine without taking out the engine itself?
Ive lowered it currently.
Si
Old Apr 30, 2017 | 11:34 AM
Sveach756's Avatar
Sveach756 is infamous around these parts
It's a semi annoying job, be careful take your time and use short blades. Lower the engine as much as you can.
Hope some of the pictures below help. The plastic side comes out with one cut near the axle.
ID:	475360   Click image for larger version
ID:	475361   Click image for larger version
ID:	475362   Click image for larger version
ID:	475363   Click image for larger version
ID:	475365   Click image for larger version
ID:	475366   Click image for larger version
ID:	475367   Click image for larger version
Old Apr 30, 2017 | 12:23 PM
OK51MON's Avatar
What shall I use to cut the pipe with?
I couldn't fit an angle grinder behind the engine, its too tight
