Fuel line under coolant reservoir ???
Old Jun 15, 2017 | 11:14 AM
Stebo's Avatar
Stebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond repute
How do I get this sucker off?
It looks like a rubber jacketed plastic line. I can pull back the rubber sleeve at both ends (i actually slit the bottom end to check it out) but the dang line won't come off. It appears to be barbed; I'm not sure, I don't want to break it, and I'm out of ideas.
Top side
Bottom side
Old Jun 15, 2017 | 11:39 AM
VAGscum's Avatar
Top side
Attachment 478458
Bottom side
Attachment 478457
Remove bolt and work fitting out of fuel rail.
Old Jun 15, 2017 | 11:40 AM
Stebo's Avatar
Originally Posted by vagscum
remove bolt and work fitting out of fuel rail.
thank you sir!!!
Old Jun 15, 2017 | 11:45 AM
VAGscum's Avatar
thank you sir!!!
Once the bolt is out it is just pressed into the rail and has o-rings to seal. You can slightly rotate while pulling towards the coolant reservoir until it comes out. Be ready to catch fuel,
Old Jun 15, 2017 | 12:39 PM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
I hate that fitting. You have to buy new orings also.
Old Jun 15, 2017 | 01:23 PM
G-Rat's Avatar
G-Rat is a splendid one to beholdG-Rat is a splendid one to beholdG-Rat is a splendid one to beholdG-Rat is a splendid one to beholdG-Rat is a splendid one to beholdG-Rat is a splendid one to beholdG-Rat is a splendid one to behold
Really? Why?
Normally O-rings on fuel system stuff (e.g. fuel injectors) can be re-used.
Old Feb 23, 2020 | 05:30 PM
Integral's Avatar
Integral is infamous around these parts
Originally Posted by G-Rat
Really? Why?
what did you replace the line with? standard fuel line or THAT specific part?
