01 Turbo Gauge Cluster Repair
So I've been having problems with looking at my Oil level on my 01 Turbo and after swapping out the sensor.. It was discovered that I got a problem in the cluster itself... We swapped another cluster and it worked.. I did a couple of quick google searches and there are quite a lot of places that can fix the cluster but I was trying to see what the forum would think about it..
Basically, Oil level sensor on the Gauge cluster needs a rebuild but I will thinking maybe LED upgrade while its out etc..
Any recommendations that I can contact would help..
I had the same issue about five years ago I sent it to North Hollywood Tach ask for Kevin (818) 761-5137. it only takes about 20 minutes to take out your cluster pretty simple and then you ship it to them. They basically replace the computer board which will solve your issue I remember correctly it was around $650.
JoeyG
Jun 21, 2017 07:31 AM
