Just joined the wing malfunction crew. Have a question
#31
have a question:
I've had the light go on for a year, at least. If I manually put the wing up, the pull the microswitches will the wing just stay up? I've topped off the fluid and that's not the problem and both sides go up, albeit, one is alittle slower than the other. I'm happy with the wing in the up position, as long as it will stay up.
will it? or will the wing lower when I disconnect one or both micro switches?
The problem is that these hydraulics are prone to leaking. Pressurizing the system will only speed up that process. The solution that replaces the rams by using screws will get past all of the hydraulic issues and leave you with a wing in the "up" position.
I replaced my hydraulics with a fixed wing and just unplugged the micro-switches - no warnings or errors.
#32
have a question:
