Warm High Idle - Not MAF
Old Jul 17, 2017 | 12:11 PM
Slider's Avatar
Has anyone had an idle issue where idle goes to 1800 after warm-up?
I have replaced the MAF because other threads suggested that would be the cause, but it did not correct the problem. Before my trip to Spokane, it was only at 1200 but now that everything is properly cleaned out, the idle stabilizes at 1800. If I blip the throttle, it goes down to 900 and comes back up to 1800 in about 3 seconds.
Ideas?
Old Jul 17, 2017 | 01:05 PM
32krazy!'s Avatar
vacuum leak affecting idle
Old Jul 17, 2017 | 01:12 PM
Slider's Avatar
Sounds good.
I am finding that I hear the blow-off now when I release boost and I don't think I used to. Do you think it's related?
Old Jul 17, 2017 | 04:03 PM
'02996ttx50's Avatar
1800? let alone, 1200 is abnormally high with 750/800 being normal. i'd also suspect a massive leak. a hunting idle from +/- from 750 to 1000 was recently solved by my replacing a maf.
Old Jul 17, 2017 | 04:47 PM
Slider's Avatar
Well, I did say it's not the MAF. It's not hunting either, it is very steady. I'll start searching for a vacuum leak and go from there...
Old Jul 17, 2017 | 06:07 PM
Macster's Avatar
Ideas?
Long shot but have you done an E-gas calibration?
However, less a long shot, and as others have offered it is more likely a vacuum leak.
Old Jul 17, 2017 | 06:30 PM
Slider's Avatar
The vacuum tip (thanks Krazy) sent me in the right direction... The turbo inlet hose on the driver's side was off. It's funny the idle was a little high (around 1000) before I went to Parade. The 1800 thing happened on the way after driving the wonderful roads south of Seattle. I'm surprised more stuff didn't fall off - the roads were horrendously bumpy in many places.
All tightened up and idling around 800.
Thanks for all the suggestions!
Old Jul 18, 2017 | 04:52 PM
32krazy!'s Avatar
glad it was an easy fix
