Slave Cylinder Failure after gt2 Conversion
Old Jul 29, 2017 | 09:05 AM
Androm3da's Avatar
Androm3da is infamous around these parts
996tt is at the shop for a tranny rebuild. Owner just emailed me that everything was ready to go, and had the clutch slave cylinder fail. Is this possible considering it had the gt2 conversion done about 4K miles ago? Been burned before by some less than honest shops, and I can't find one instance of a failure subsequent to the gt2 conversion. Thank you in advance for any input!
Old Jul 29, 2017 | 09:15 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
When you do the conversion you have to get all of the pentosin out of the line, and I mean all of it. The pentosin ruins the seals in the cylinders. Your slave likely had some fluid left in it. Very common issue, it happens to most who do the conversion. Have them flush the lines again and replace the slave.
Old Jul 29, 2017 | 09:49 AM
Androm3da's Avatar
Thanks so much for the response, this is helpful information. Should brake fluid be used to do this or would hydraulic oil be more appropriate?
Old Jul 29, 2017 | 10:15 AM
brnrdtns's Avatar
Use brake fluid that is called for. Flush a lot of it through. You can use cheap stuff from the auto parts store as the fluid does not have to resist heat like the brakes do.
Old Jul 29, 2017 | 10:20 AM
Androm3da's Avatar
Thanks so much, this is very helpful.
Old Jul 29, 2017 | 11:22 AM
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
This. BBi just rebuilt mine with new seals due to improper installation and not getting the pentosin out of the system.
