Cracked front diff - Repairable?
Old Jul 29, 2017 | 06:16 PM
Slider's Avatar
This is what happened on my way to parade. Does anyone know if this kind of damage can be welded?
Old Jul 30, 2017 | 12:41 AM
VAGscum's Avatar
It can be. However the issue would be if whatever caused the crack may have also distorted the bearing and seal mating surfaces beneath. I have a spare diff if you need one. Just PM me.
Old Jul 30, 2017 | 06:58 AM
mxracer's Avatar
mxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond repute
It can be welded no problem by someone who knows what they are doing. Pre-heat and not putting too much heat into a small area of the part as its being welded is key here so as to not warp the seal/bearing bore.
As for the bearing and seal surfaces, a quick check with a dial bore gauge or telescoping gauge and mic would tell that story. Worst case is weld buildup and re-machine.
I have done similar type repairs on other equipment in the past. If you take it to a machine shop (not just a welder) you should be ok.
