loss of clutch pedal pressure?
The other day I went to drive the car, left over night, and the clutch pedal had 1/4 pressure. Super low engagement point in comparison to the high engagement point. I've searched but the only answers I see are bad accumulator or slave cylinder. It doesn't apply to me because I have the gt2 mod. It has a Sachs clutch and 964 rs lwfw.
No fluid inside or outside the car. Could it be a bad master cylinder? (Based on the 1 post I saw on 6speed by the owner of speedtech exhaust)
Any ideas on what to check? It's been parked since the issue. I restarted the car shortly after parking it in the garage and had full pressure again.
you need to bleed the system. all you've done essentially is lose the accumulator and eliminate pentosin from the shared ps system, and now use dot4. still you have a slave and fluid, and you probably have air ( or loss of fluid? ) in the system.
GL. i have relatives in brick township. pls send them my regards.
