Engine Compartment light stays ON
Old Oct 19, 2017 | 12:47 PM
acmf74's Avatar
acmf74 is infamous around these parts
When I shut the car off the engine compartment light stays on.
Is there a switch that needs to be replaced?
TIA
Old Oct 19, 2017 | 02:02 PM
Third-Reef's Avatar
Third-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond repute
Is the frunk latched? If it is not the engine compartment light stays on.
Old Oct 20, 2017 | 03:11 PM
'02996ttx50's Avatar
I had the same issue intermittently after long ago swapping in led’s for all the bulbs interior and engine comp and frunk.
Not knowing what else to do or try, I simply unplugged the one in the engine comp a few times, and bent the alum tabs a bit and sure enough.
No more issue. Was luck or coincidence, I am sure
Old Oct 20, 2017 | 05:41 PM
Slider's Avatar
The light will stay on if the frunk is open - whether the car is on or not. I'm pretty sure it will go off if left on for too long. (I don't remember the time required for that one)
