Intercooler Inlet Scoops for reduced IATs
Old Nov 4, 2018 | 11:23 AM
  #46
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
Here you have it oem style. Like mine.
https://www.flickr.com/photos/dav-t/15346728796
Old Nov 5, 2018 | 07:41 AM
  #47
s65e90's Avatar
s65e90 is infamous around these parts
A random pic of a car doesn't help. How do you know how it's adjusted in that pic?
Old Nov 5, 2018 | 07:47 AM
  #48
Slider's Avatar
That one looks like the wing edges are pointing down but the wing is more level - hard to say for sure from the from the angle. I originally built the edges to be level when the wing was angled the way I wanted it. I have since added more down angle at the front so the edges are pointing a little down now.
Old Nov 5, 2018 | 11:22 AM
  #49
Well if the wing edges are mounted differently to your wing, then its not possible to compare the wing angles.
Old Nov 5, 2018 | 11:47 AM
  #50
Slider's Avatar
Correct - At least not if you are using the tips as your reference for the wing angle...
