Drop engine to reapir coolant pipe, time to upgrade air intake?
Old Dec 23, 2017 | 09:21 PM
Timothykee's Avatar
Timothykee is infamous around these parts
One of the coolant pipe is leaking and i cant see where. Engine probably has to come down. Should i take the chance to upgrade the air intake that is easy to do with the engine out? Anyone comments on Markski's kit? https://www.markskituning.com/produc...ndable-tubing/
Is it worth doing/the money?
In addition the following will be renewed:
1. all coolant pipes
2. coil
3. spark plugs
4. check turbos condition, e.g. shaft play
TIA!
Old Dec 23, 2017 | 11:21 PM
'02996ttx50's Avatar
aside from dealing with your "suspected" coolant issue(?)
the rest is a tune up. why mess with the intake. there are lots of things you can do "sequentially" without messing with "intake" first.
there is a 15+ year old "step by step" protocol for upgrading the power output with bolt on upgraded parts. you can do it all at once? or piecemeal. messing with the intake is NOT where to begin.
study those with these cars and their upgrades, that have come before you. GL.
Old Dec 24, 2017 | 01:10 PM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
I have the markski soft inlets and I like them.
Old Dec 27, 2017 | 07:09 AM
Rvca3112's Avatar
Rvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant future
I say go for it depending on how everything else looks if/when the motor gets dropped.
Old Dec 27, 2017 | 08:23 PM
s481's Avatar
s481 is infamous around these parts
When I pinned my coolant pipes Marski set me up with a modified version of his soft inlet pipes.
Give him a call - very honest guy and great to work with.
You won't believe how tight some of the bends/pinches are with the stock pipes.
I don't know where your budget ends as there's a lot that can be done both for performance & maintenance when the engine is out.
However, with the engine out you're basically paying for parts - install of the soft pipes was a breeze.
MadWhip
Mar 4, 2015 07:21 AM
2011PorscheCaye
Cayenne 958
Apr 4, 2012 05:25 PM
batmobl
14
Oct 12, 2011 01:23 PM
GL996TT
Jan 4, 2007 03:47 PM
