How good are gtx3582r
Yeah, think I’ll go with the tials, although, I do plan a basic engine build in the near future. Does it require a full engine build to do the rods in these engines?
No rods alone with head studs will make the motor very stout.
Now, to stir up questions again. Someone has just pointed out the gen 2 Garrett GTX3576R. From what I’m reading it spoils as fast as gtx3076r but flows up top better and in future can be upgraded to 3582 if necessary quite easily. Hmmm, anyone tried one?
the 3576 used the gt35 turbine and the 3076 compressor. It will spool slower. On a motor our size and limited rpm range, you will gain nothing from doing this until running 4 digit hp. The gt30 turbine flows more than enough.
Ok, what are your thoughts on these gen2 gtx3076r vs maybe tial 3076? They seem to be highly rated but is that just on higher revving engines Again? Also, do you know how many hours labour it should be to upgrade rods? Thanks
as for doing rods and studs and the hours of labor, you need to be more specific. Are you just dropping the car off somewhere and having them pull the motor, build it, and put it back in? You going to pull the motor and send it complete somewhere? Are you going to pull the motor and strip it down to just a long block and send It? Have to know more before giving you time to do the work.
For rods I would need to drop off the whole car. I’ve been told it’s 6-8 just to remove and replace the engine?
Turbos. I’m planning on customer headers and another new Exhaust as I think I would need it on this size of turbo so probably go with the gtx then and also, the sound of external wastegates
With the engine build, I am trying to decide if I should go with a full built bore and stroke 4.0 litre or just rods and studs? If labour on rods is almost as much as full engine build then I may consider going the whole hog but if it’s not to bad I’d be happy to just address the weak points then wind up the turbos. Thanks for your help
Well if your just dropping a car off at a shop, your looking at about 60 hours for engine removal, rods and studs install and then engine install.
if your going to do that's, you'll want to build the whole car at 1 time. That includes fuel system, turbos, probably a stand alone, trans build, axles, etc.
for building a larger motor, I would only go to a 3.8. Larger than that they have had issues with liners cracking because they are too thin at super high hp
for the tial 3076, you would be fine running stock manifold that are ported.
Just a suggestion here, you need to truly determine your end goal and not try to reinvent the wheel to get there.
Ok, thanks for your help. I’m just trying to gather information to help me determine which route to take. My mind goal was circa 1000 bhp at the crank but I think that will certainly require new rods. Wanted to do it in stages if that’s possible.
you can build in stages to a point. With your current setup, you'll limit out the fuel system you have with 3076. You will make more power though and can stay there until you decide to rebuild the motor. 750whp and 650wlb is really the max limit of the stock motor. You have to tune carefully to run that as well.
a simple turbo upgrade, filters on turbos, and a new tune will get you nice gains until you want to do the motor.
Sounds great. So, fuelling. I have everything stock except 60lb injectors. So, to get around 750whp I’m sure I’ll need more. What would you suggest so as not to have to upgrade injectors again when building the motor? Thanks
injector and fuel system will depend on what fuel you plan on running. If use e85 it will require a much larger fuel system. I think you said before though that you don't have that easily available. In pump gas and race gas you can use much smaller injectors and pump.
