Which 10mm head stud - opinions wanted
Old Jun 8, 2018 | 09:40 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
Originally Posted by ragpicker
Cheers brnrdtns, I've had a look and it appears that A1 are no longer in business? Their FB page hasn't been updated since 2013 and their website is no longer active.
Its all getting frustrating now because there doesn't appear to be a stud which doesn't require a re-torque unless you go 12mm which my guy doesn't want to do. The EVOMS solution appeared to be the best but they have split with their manufacturing arm and now just use the Raceware studs.
He's currently waiting for EVOMS to contact to inform whether they will be ok without a re-torque.
Looking around another thread on here, there's a guy running a lovely yellow 996 turbo and it appears that there was no re-torquing with his Raceware studs.. Fingers crossed.
What are your goals? The guys who pushed their head gaskets on racewears don't post up about it and don't want it to be talked about.
Old Jun 8, 2018 | 10:05 AM
ragpicker's Avatar
ragpicker is infamous around these parts
Goals are an engine which can withstand 750-800 crank reliably. Its a built 3.6 motor, the only issue is this head sealing. As he's already paid once to have the cases split, new bearings and shells etc he is loathed to have it all disassembled again to machine for 12mm studs if he doesn't have to... I can see his point as he's already paid once, and now paying again...
Old Jun 8, 2018 | 10:26 AM
s65e90's Avatar
s65e90 is infamous around these parts
Did you see my post? Why not look into heat cycling the motor on the stand before it gets re-installed? Sounds much easier.
Old Jun 8, 2018 | 10:52 AM
brnrdtns's Avatar
If you can't find the Evoms 10's then you are going to have to go to 12's to be reliable. Anything else and you are taking a chance. Just the way it is.
Old Jun 8, 2018 | 11:27 AM
Stebo's Avatar
Stebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond repute
Doesn't ARP make custom anything you want? Did you try them?
Old Jun 8, 2018 | 11:57 AM
brnrdtns's Avatar
The ARP material isn't better than stock. The A1 studs somehow have some unique material that is stronger. The studs on these motors are really long as they go through the head as well as the cylinder housing so it is hard to find studs that won't stretch. 12mm is around 53% bigger than 10mm when you do the math (πR^2) so it solves the problem.
Old Jun 8, 2018 | 12:09 PM
ragpicker's Avatar
Great idea, any info on how to do this? Has anyone done it successfully out of the car?
Would be great and answer a lot of problems for lots of people if it can be done!
Old Jun 19, 2018 | 01:14 PM
yeah Tim and I built one before. he made adapters for water ports. rigged up a water heater. got the engine warmed up to about 200 degrees. I've used racewares a couple times. on my 996TT they held up stout for up to 900whp or around 30 psi. once I leaned on it 35-40psi it sent the gaskets right out - no orings. then I put it back together with O -rings and it held 1100whp no problem until I sold it.
on my 997 I made 1500whp on racewares and then head gasket blew after few k miles. using stock 3.8 GT3 gasket and small steel wire rings. now I switched to a composite gasket, big steel fire rings and custom made 10mm studs.
so really depends what you want to do and how much power you want to push. if its really 750-800whp I wouldn't hesitate to send racewares in there all day long. the build has to match the goals, the weakest link will always show.
there have been blown gaskets with just about every stud there is including arp, raceware, evoms 10mm & 12mm. people don't talk about any of them or they just don't make enough power to push them
#TeamAIM
Old Jun 20, 2018 | 01:59 PM
Fadi's Avatar
Fadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond repute
I have the same experience on 996tt and raceware studs, all was 100% fine and did THOUSANDS of pulls up to 1.8-1.9bar on my last setup, gt3076s and about 900whp
Once I tried 2.1-2.2bar the heads went bananas
Refreshed the engine and runs like a champ on gtx2863s and only 1.3-1.6bar for now, but I am really confident can do 1.8-1.9bar safely again for a long time
PS: My tuner told me to keep her till 1.8bar, but I was too brave
Old Sep 17, 2018 | 05:01 PM
David Rohrer's Avatar
David Rohrer is infamous around these parts
Reviving a thread here to see if we got a final answer on re-torquing raceware 10mm studs after a heat cycle. I am going through and replacing stock studs next month and raceware 10mm seem to be the best. 650hp power goal so nothing crazy.
Old Sep 17, 2018 | 06:16 PM
brnrdtns's Avatar
That will work, but for a re tourque you are looking at tearing it all back apart again, engine out, cams and baskets off, big deal. For that power level just use one torque.
Old Sep 18, 2018 | 07:27 AM
raceware reliable up to 850whp and under 2bar of boost. no need to retorque.
#TeamAIM
e8_pack
15
Nov 4, 2016 07:02 PM
johnny.dangerous
Sep 11, 2015 02:39 PM
GTRNICK
Sep 24, 2013 07:48 AM
porschenaround
Dec 3, 2008 03:58 PM
