Knock sensor cross reference
Old Aug 24, 2018 | 11:53 PM
itschris's Avatar
itschris is infamous around these parts
Hey guys, so apparently from others peoples good advice a Rat got to the plug and chewed it up. My repair shop called Porsche up and they said I’m SOL on a plug. I’ve done many searches and research over the net looking for this plug. Does anyone know anyone or do you have a spare plug for a knock sensor bank 1 ? I searched that someone was able to use a Volkswagen plug and worked but couldn’t find any part number reference ? Any help would be appreciated as my car is in parts right now thanks
Old Aug 27, 2018 | 11:44 AM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
Not sure I understand your post to be honest, so you need a new knock sensor? other? Please clarify, maybe others would help if they understood what your issue is.
Old Aug 27, 2018 | 01:27 PM
itschris's Avatar
Hey Bear, thanks for the response. Sorry if I was unclear in my post. I'm looking for the plug, that plugs into our knock sensor 1. Apparently, it went through 2 PPI's w/o triggering the check engine light. From searching different boards, I heard a VW or Audi knock sensor plug should work. The repair shop called Porsche last week, but they said they dont sell the plug by itself. Only the Big harness. Thanks
Old Aug 27, 2018 | 02:10 PM
JSBear's Avatar
I found these links, hope they help. Maybe others will chime in.
http://www.renntech.org/forums/topic/28652-p0327-porsche-fault-code-210-knock-sensor-1-please-help/
https://www.6speedonline.com/forums/996-turbo-gt2/182710-p0327-porsche-fault-code-210-knock-sensor-1-help-pleas.html
I'm guessing you may be able to take the plug to the VW / Audi dealer, and they could help. I may have an Audi knock sensor from a 2001 Audi S4. I will look tonight, maybe same plug.
Old Sep 5, 2018 | 02:24 PM
check out ebay item 151847537860 , I believe that is what you need. I think its called bosch late 2 pin female connector
#TeamAIM
roncooper
Jun 30, 2015 07:30 PM
BB987
Wheels/Tires
Oct 12, 2006 06:41 PM
