What OBD2 signals do we get from the 996tt?
Old Mar 24, 2006 | 01:47 PM
Joe Weinstein's Avatar
Which of these OBD2 signals are available from the 996tt diagnostic port?
Calculated Load Value
Coolant Temp
Intake Air Temp
Long Term Fuel Trim bank 1 / bank 2
Mass Air Flow
Manifold Air Pressure
O2 Trim bank 1 / sensor 1 through bank 2 / sensor 4
O2 Voltage bank 1 / sensor 1 through bank 2 / sensor 4
RPM
Short Term Fuel Trim bank 1 / bank 2
Spark Advance
Throttle Position
Vehicle Speed
Old Mar 24, 2006 | 02:06 PM
prubin's Avatar
X1
prubin is infamous around these parts
Well I can confirm the Mass Air Flow sensor error code, because my car threw this code when I had to replace my MAF:
P0102 - Mass Air Flow Sensor (G70) Signal Too Low"
Old Mar 24, 2006 | 03:49 PM
Ruiner's Avatar
Coolant Temp
Intake Air Temp
Mass Air Flow
RPM
Spark Advance
Throttle Position
Vehicle Speed
Here is what I get using my pocketlogger ODBII scanner:
Calculated Load
Coolant Temperature
Short Term Fuel Trim Bank X
Long Term Fuel Trim Bank X
Fuel Pressure (Gauge)
Intake Manifold Absolute Pressure
Engine RPM
Vehicle Speed
Ignition Timing Advance
Intake Air Temperature
Air Flow Rate from MAF
Throttle Position
Oxygen Sensor Bank X Sensor Y (I only see the downstream bank 2 sensor 1 or 2 on mine, however).
Old Mar 24, 2006 | 03:55 PM
wross996TT's Avatar
I get the same as Ruiner.
Old Mar 24, 2006 | 03:58 PM
Ruiner's Avatar
A. What are you using?
B. Are you able to see your "upstream" O2 sensors? O2 1, bank 1 and O2 1, bank 2?
Old Mar 24, 2006 | 10:55 PM
EXPLICIT's Avatar
EXPLICIT is infamous around these parts
What OBII scanners are being used by most here? Would a standalone unit or laptop program with cable be a better option? Sorry to hijack.
Old Mar 24, 2006 | 11:01 PM
wross996TT's Avatar
A. Using the same as you ...pocketlogger
http://www.pocketlogger.com/?pid=help
B. Don't know?
Oct 6, 2015 06:13 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
gjpearce
Sep 30, 2015 04:26 AM
ECS Tuning - BMW
Sep 29, 2015 01:18 PM
WEEED
Cayenne
Sep 25, 2015 10:45 PM
