996TT suspension refresh
Recently grabbed some rear KONI special active rear struts in the Pelican sale. Just bought the hard to find front set from KONI NA direct. Poking around I saw recommendation to replace the upper front strut mounts since those have plastic wear parts in them along with the front strut bearings. I already recently replaced all four bump stops and bellows are in fine shape.
I also bought new rear drop links.
Missing anything I should refresh? 2004 w ~35k miles.
996-343-015-04
996-343-016-04
996-343-501-00 x 2
PAF-003-923-OEM x 6
996-333-069-04 x 2
996-343-015-04
996-343-016-04
996-343-501-00 x 2
PAF-003-923-OEM x 6
996-333-069-04 x 2
996-343-015-04
996-343-016-04
996-343-501-00 x 2
PAF-003-923-OEM x 6
996-333-069-04 x 2
Spoiler
996-343-016-04
996-343-501-00 x 2
PAF-003-923-OEM x 6
996-333-069-04 x 2
Sorry for the delay. Everything is great!
Front PNs (direct from KONI NA) PN 8745-1422
Rear PNs I got from Pelican PN 8245-1255
Nice score on the KONIs—those should really tighten things up! With only ~35k miles, you’re probably in great shape overall, but since you’re already diving in this deep, it might be worth checking the front control arm bushings and sway bar end links if they haven’t been done. Also, double-check the top strut mount torque specs when installing—some folks have had noise issues from that. Otherwise, sounds like you’ve got most of the key wear items covered
DaveSen
Apr 24, 2014 02:53 PM
pwdrhound
Apr 5, 2014 07:32 AM
ExclusiveTT
Jun 1, 2010 12:49 PM
flash68
17
May 13, 2009 08:55 AM
