Where to buy Tequipment rollbar
rockitman...great instructions. I used your gt3 install tips a few weeks ago and it made it a lot easier.
one question....your install of the tequiptment rollbar looks pretty straight forward, where does the 7-10 hour timeframe come from? Is that just hours and hours trying to get the bar to line up right?
also, after doing it yourself, would you recommend it? Or would it be a better idea to pay the $500 to have it installed professionally?
thanks again man.
thanks again man.
thanks again man.
thanks again man.
1) They know what they are doing and have installed them before.
2) The are careful with the interior and don't scratch or damage anything...
Very questionable attributes of my local dealer. Most likely, they will never lay their paws on my GT3 unless absolutely necessary...ie and electrical problem or the like. I plan on doing most routine maintenance tasks like oil and brake ect changes. If I need an alignment, I will probably drive many miles to bring it to a place that tunes competition Porsches...My dealer was allocated 1 GT3, mine and I don't want it to be the test guinea pig, if you know what I mean. I reserve their service for the Cayenne only...My daily beater!!!
I actually have a great service guy here in the dc area. He really takes care of me. But they would have to estimate 10-12 hours labor for the job. Basically like you said, to make sure they don't mess up any of the interior. My 6 hour quote was from Autothority here in VA.
Re: Where to buy Tequipment rollbar
Originally posted by jcramair1
Who has the best price for the Tequipment roll bar and Harness for the GT3 seats? I heard somewhere along the lines that the harness belts can also come in white??
Also, when you guys say 'crush the rocker panels', what do you mean. Do you not cut out any plastic to make room? It sounds like you just smash the bar into the plastic?
OK Rockitman If you are 6'7" then you probaly have your seat back as far as possible with the GT3 seats. Do you think that the Stock sport seats in an more upright setting would fit with the Porsche bar. I am not sure if I want to go all the way and get the Seats just yet.
It's not all the way back, since I don't like the back of the headrest portion of the seat making contact with the harness cross bar. The stock sport seats will work, but you can't slide them all of the way back...
Just a tip!! I used a porta - power to spread the front legs apart and into position when lining up the bolt holes. Made for a really painless install.
Just in case you don't know a porta - power is a hydraulicly actuated ram (speader) that I placed between the two front bar legs and then pumped to spread them apart.
Porta power
Andreas
Porta power
Andreas
Okay,
Here is the next question. I have to be able to use my back seats for my kids. I would like a rollbar that I can put in and take out. Can DAS or someone custom build one for me that has fixed mounts with maybe quick release pins or something? The reason I can't just go with a Techquipment bar without the brace is I do track the car and need a place to route my rear belts. Currently I am using a Stable Energies Harness Bar but you can't use that with a Roll Hoop.
HELP! and thanks!
HELP! and thanks!
Oh what is the Diameter of the tubing?? on either the Factory porsche peice or any other bar out there. It looks like the Porsche peice is made out of stainless steal. is that right I am taking the pictures of rockitmans car and looking at the seat position compared to my seat position.
right...Porsche bar is stainless steel, but the dassport is mild steel and will require painting.
If you're interested, e-mail Mackenzie Horn at CDOC (mackenzie@cdoc.com)...they sell both the tequipment bar and dassport one.
DB-Design-Group
Oct 1, 2015 12:25 AM
DB-Design-Group
Maserati Vendor Classifieds
Oct 1, 2015 12:21 AM
petron5000
Sep 6, 2015 11:20 AM
