Question about rpm redline
Old Apr 27, 2006 | 12:03 AM
willcoxmd's Avatar
willcoxmd is infamous around these partswillcoxmd is infamous around these parts
The tach gauge says redline is about 6500 rpm in my '03 TT. My question is now that I have upgraded to a Stage 4 system with the GIAC flash, has my redline number changed? Can I push a little more or not? I was running around with a friend's 575 Maranello and rev'd a little too high b/w 3rd and 4th, but the "rev limitor" didn't seem to kick in until a much higher rpm...like 7000+
I don't want to destroy my engine, so some advise is much appreciated
Old Apr 27, 2006 | 12:07 AM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
With your upgrade, the redline should be around 7000-7200 rpm.
Old Apr 27, 2006 | 12:27 AM
I know other tuners kick up a notch.. not sure about GIAC...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Apr 27, 2006 | 02:16 PM
dyu2118's Avatar
dyu2118 is infamous around these parts
I noticed that my rev limiter hit beyond 6500 when I accidentally shifted out of 1st too late.
Old Apr 27, 2006 | 02:51 PM
lee lovell's Avatar
lee lovell is infamous around these parts
I have the stage 4 giac also.
The rev limiter is untouched unless you have asked for it to be raised. Dont worry the rev limiter cuts in just the same as pre modding it.
Old Apr 27, 2006 | 02:58 PM
willcoxmd's Avatar
What is a "safe" rpm to shoot for? do you guys try hit the redline? I thought I read somewhere max HP/torque was something like 5500 rpm. I guess i'm asking if I want to make the most efficient/fast 0-150mph, what rpm should I shift gears? Sorry, i'm a bit of a newbie to this kind of power.
Old Apr 27, 2006 | 03:19 PM
BBGT2's Avatar
BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !
With my Protomotive tuning kit my rev limiter is not at 6500RPM's anymore havent found out where it is as I shift around there when nailing it but that annoying cut off is gone, thank you PROTOMOTIVE.
Bajo
Old Apr 27, 2006 | 03:48 PM
iLLM3's Avatar
My stg 2 FVD tuning rev's out at like 7-7200
Old Apr 27, 2006 | 05:04 PM
Toothzilla's Avatar
Toothzilla is just really niceToothzilla is just really niceToothzilla is just really niceToothzilla is just really niceToothzilla is just really nice
I swear after my EVO stage II I'm also at 7-7200.
Old Apr 27, 2006 | 05:10 PM
Mr Kram's Avatar
Mr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond repute
If your car is still under warranty, you should be careful when increasing the factory redline.
Old Apr 28, 2006 | 12:05 PM
Dirty Mac's Avatar
Dirty Mac is infamous around these parts
I think that we are talking about two seperate items: the redline and the cutoff.
The redline indicates the safe operating range of the engine. It is a function of the internal engine parts. You would need to lighten and/or strenghten the pistons, connecting rods, valves, gaskets, etc. to increase the redline (ie the safe operating range).
That said, the redline is not some magical speed where everything falls apart but is there to indicate the safe operating range.
The cutoff is there to ensure that you don't accidentally rev to a point where failure is inevitable. By increasing the cutoff, you risk spending more time in the danger zone which will definitely result in excessive engine wear if not failure.
So bottom line is increasing the cutoff does not increase the redline.
Old Apr 28, 2006 | 09:25 PM
willcoxmd's Avatar
I like that thinking. That makes more sense to me. The mod's have increased my power, but I should operate in the same rpm spectrum to protect my engine. The ECU hasn't been reprogrammed to rev higher ( or require higher rev's) thanks boys
Old Apr 28, 2006 | 09:41 PM
drjoe's Avatar
drjoe is a jewel in the roughdrjoe is a jewel in the roughdrjoe is a jewel in the roughdrjoe is a jewel in the rough
shift at 7000k....because if you shift any earlier, the next gear will drop to a LOWER rpm (less power)
COBB Tuning
Mar 29, 2016 09:26 PM
alevine
Nov 4, 2015 10:05 AM
jyupitt1
Aug 31, 2015 12:58 PM
