how to remove driver side AC vent
Old Apr 28, 2006 | 03:10 PM
AIRjordan23's Avatar
AIRjordan23 is infamous around these parts
hey...how do you get to the inner torx screw...
you need to remove the light switch..
whats the process..
thanks!
Old Apr 28, 2006 | 05:41 PM
anyone? someone has to know..
Old Apr 28, 2006 | 06:09 PM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
Two torxs on the sides, then you have to remove the headlight plastic switch part that turns to turn the lights on/off(use a small jewelers screwdriver underneath to press on the metal tab upward). After that, loosen the nut holding the black plastic round headlight indicator thing out. After you get that out, there is a torx on the right side. After that is out, you will have to use a set of pliars to turn the actual headlight switch 1/5 of a turn to unlock it out of the vent assembly...then the whole vent should pull straight out.
Old Apr 28, 2006 | 06:55 PM
thanks...will give it a shot right now...
Old Apr 28, 2006 | 11:32 PM
wross996TT's Avatar
Here you go:
Old Apr 29, 2006 | 02:19 PM
wross thank you much! very helpful
Old Apr 30, 2006 | 09:15 AM
wross996TT's Avatar
Glad I could help.
Jul 29, 2019 11:13 AM
rnl
Aug 26, 2015 02:36 PM
tkeck3
Aug 25, 2015 02:52 PM
Zero911
Aug 24, 2015 06:51 PM
pwdrhound
Aug 23, 2015 07:36 PM
