Picture of Outside Air Temp Sensor for GT2 Bumper?
I recently had an OEM GT2 front bumper installed and the shop left the outside air temperature sensor hanging by the wire.
Does anybody with a GT2 front bumper have a close-up of what it is supposed to look like? I would like to see it and order the correct part.
Thanks,
Adam
Thanks,
Adam
I had an GT2 OEM bumper conversion done too on my TT.
It appears that the Gt2 bumper does not have an appropriate sized hole for the air temp sensor to be secured. My sensor hangs too and gives a diff reading. A 'zip tie" is probably the solution......
spidey:
Did you secure your with a zip tie? I'm not sure what the secure it to. Do you have any pics?
Also, I assume when you say "the GT2 bumper does not have an appropriate sized hole (many jokes come to mind right now ) for the air temp sensor" you mean the stock turbo hole in the air duct is smaller in diameter. True? Maybe there is a larger rubber grommet available for the GT2. Thought?
Thanks,
Adam
Thanks,
Adam
04-28-2022 12:38 AM
