Does ECU Have to Re-learn After Diverter Valve Install?
I just had the EVOMS billet diverter valves and new Bosch FR7's spark plugs installed by my mechanic. When I called to pick it up he said the car is hestitating at idle, jumping idle and the DME Torque Converter light came on. Does the ECU have to re-learn anything when the new diverter valves are installed?
Also, it was throwing ABS/PSM Failure lights for a while now. He cleaned the MAF with MAF cleaner and still the problem persists. Any ideas?
Thanks in advance,
Adam
Thanks in advance,
Adam
Bosch FR7s?? Un uh.. I hope you got FR6s? Also the ECU doesn't need to relearn like that after a DV install. Sounds like some vacuum lines are either leaking or not hooked up right? Also that weird "searching" it does at idle is usually when a maf is either not working properly or when it's not plugged in properly...
Thanks in advance,
Adam
Thanks in advance,
Adam
Hang in there
Shadowman
Thanks all. I will have my mechanic check for any hose leaks, etc. and make certain the MAF cleaner did not leave any residue. Forgot to mention he also put on a K&N air filter. Maybe the oil from the filter got on the MAF?????
Thanks,
Adam
Thanks,
Adam
My hoses are stock. Hopefully something is not snug or fit right it it will rectify itself. Why such probelms w/silicon hoses?
Adam
Adam
Any smart mechanic would have captured a baseline of all sensor readings prior to any mods. Simply have him look at the current readings which will give him a better clue as to what the problem is.
04-28-2022 12:38 AM
09-01-2015 03:16 PM
08-20-2015 12:17 PM
ECS Tuning - VW
08-19-2015 08:58 AM
