My Car is acting up !!!!!
Old May 17, 2006 | 09:39 AM
Divi996tt's Avatar
Divi996tt is infamous around these parts
I started to have this problem about a month ago. I will try to start the car and it will not crank up !!!! I will try a couple more times and after a few tries, the car will start. I guess the starter was giving away. Then, this morning, when I tried to start the car, all kind of noises from the starter !!!! All the dash lights will come up blinking, the windows will come up and down by itself !!!!!!! Can the car exhibit all kind of electrical malfunctions from having a bad starter???
What's going on?, car won't start. !!!
Divi
Old May 17, 2006 | 11:41 AM
Zlatko's Avatar
Zlatko has a brilliant futureZlatko has a brilliant futureZlatko has a brilliant futureZlatko has a brilliant futureZlatko has a brilliant futureZlatko has a brilliant futureZlatko has a brilliant futureZlatko has a brilliant futureZlatko has a brilliant futureZlatko has a brilliant futureZlatko has a brilliant future
*hopes to god you're talking about the expedition*
Old May 17, 2006 | 11:59 AM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
Are you sure it is the starter. It may be a bad battery contact and you are not getting the correct amps to turn the car over and making the ecu think it is not getting enough voltage. I would try to disconnect and reconnect the battery and go from there. Also you may have a battery with some bad cells and may only be feeding the car 8-10 volts. Best of luck!
Old May 17, 2006 | 12:01 PM
Cody_1's Avatar
Senior Member
Cody_1 is infamous around these parts
Maybe the battery? The window thing may blow this theory, but I've had starters make all sorts of noise when the battery was low/shot. I'll leave it to the experts on this board, but the battery would be the first thing that I check.
- Rich
Old May 17, 2006 | 12:45 PM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
110% this is
the battery
Old May 17, 2006 | 12:54 PM
Divi996tt's Avatar
Hum, I just called Porsche road service and they sent a tow truck. They tried a jump start but no luck.. So its gone to the dealer- 60 Miles away !!!!!!!!
Sucks and yes it is the TT.
Divi
Old May 17, 2006 | 04:53 PM
girthboy's Avatar
girthboy is infamous around these parts
that really blows. I wish you best of luck and let us know how it pans out and what the problem was.
Old May 17, 2006 | 05:05 PM
buddyg's Avatar
My car did the exact same thing and it turned out to be a loose battery cable.
Old May 17, 2006 | 09:35 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
could be lose connection at the starter ...any elec smell?? like arcking ... also ckeck your ground ,,,,it does not thke much to loose volts...
Old May 18, 2006 | 06:34 PM
Chet M's Avatar
Chet M is infamous around these parts
How funny...I have the exact same problem. I read this post earlier as I was charging up the battery in my 996TT. Went back to start and nothing......same problem. Bought a new battery and all is good.
Old May 19, 2006 | 07:23 AM
Divi996tt's Avatar
THE BATERRY !!!!!!!! Wow, they replaced it under warranty . They also adjusted the clutch .
Thank Guys
Divi
Old May 19, 2006 | 07:34 AM
M3CAB's Avatar
Glad to hear it was just the battery. What did they do to adjust the clutch?
Old May 19, 2006 | 10:17 AM
Josh's Avatar
Josh is a jewel in the roughJosh is a jewel in the roughJosh is a jewel in the roughJosh is a jewel in the rough
Ever have a battery go dead before? Heh.
The batteries used in the 996 are pretty bad. When your new battery goes bad, and it will, I'd recommend a non Porsche alternative like Interstate.
One thing a lot of people overlook though on these Porsche batteries is you need to regularly check the amount of fluid in them.
Old May 19, 2006 | 10:47 AM
M3CAB's Avatar
I agree 100% about the OEM batteries. When I bought my car 2 years ago with only 5k on it, I had to replace the battery within months of ownership. I ended up with an Interstate battery which I know would not do me wrong. Plus it was only about $75 versus whatever the OEM costs.
Old May 19, 2006 | 11:03 AM
Divi996tt's Avatar
I will be picking up the car today. When I called the dealer, they just told me that they replaced the battery and that they adjusted the clutch- Maybe at the pedal ?????
The weird thing is that the car will be ok for a week or two, then it will act up a couple of times and then ok again ( I guess it was cycling).
I though it was a check free battery !!!!!!!
Divi
