Bay Area Porsche Autrocross School in FEBRUARY!
Old Dec 26, 2003 | 06:12 PM
Joe Weinstein's Avatar
Thumbs up Bay Area Porsche Autrocross School in FEBRUARY!
The GGR/Porboys Beginners Autocross School
Date: February 21, 2004. Saturday from 8:00-4:00
Cost: $85 a person, includes lunch and t-shirt
This event is limited to 47 students and is intended for members who have
little or no autocross experience. Skills that we will be working on
include: skidpad, course walk, course analysis, worker positions, and a lot
of seat time on the course! This is also a good events for couples, family,
and friends to spend a day learning together. Two drivers can share one
Porsche for this event, with no reduction in driving time.
To register, send check, made payable to "PCA-GGR":
Howard Yao
62 El Bonito Way
Millbrae, CA 94030
If it rains that day, we will reschedule to event as soon as possible. Make
sure you have at least half a tank of gas and that the carefully check your
tire pressures. If you do not know the optimal tire pressures for your car,
a rule of thumb is to add 4-5 psi to the factory recommended pressures.
You'd rather have more air than less, so you don't scuff up your tire
sidewalls.
The only safety equipment required is a helmet and the standard seat belts
in your car. If you do not own a helmet, we have a limited amount of loaners
on a first come first serve basis. Keep in mind, our loaners helmets are old
and stinky - a last resort. Buying or borrowing a helmet from a friend is
the best route.
If you do consider buying a helmet, either a motorcycle or autoracing helmet
will do fine. Make sure the helmet is DOT and SNELL approved. You probably
don't need to spend over $200 for a helmet, there are a lot of good ones for
about $150 at your local motorcycle shop. The brand isn't as important as
the fit and comfort of the helmet.
If you have a child between the ages of 16-18 and would like to participate,
please print out the following form, sign it, and return it with your
payment - http://www.pca-ggr.org/pdf/GGRAXParentalConsent.pdf
Remember to include the year and model of your car and also your T-shirt
size when you send in your check! See you in February!!!
joseph_number1
Jul 19, 2018 05:45 PM
Oct 6, 2015 05:20 AM
drinaldis
Sep 28, 2015 01:37 PM
Aug 21, 2015 06:34 AM
Aug 20, 2015 12:17 PM
