New Rubber over OEM Rims - Pressure?
Old Jun 16, 2006 | 08:21 AM
03MiamiTT's Avatar
03MiamiTT is infamous around these parts
Question New Rubber over OEM Rims - Pressure?
Just put on Michelin PS2s over the standard 18" OEM Rims...
They are the Turbo standard tire sizes of 225/40/ZR18 and 295/30/ZR18...
For all of you running on PS2s (and I suspect that is quite a few of you) what are your ideal front and rear tire pressures?
Please post the pressures here and I can always tweak it a few PSI one way or another depending on my feel.
Thanks!
Old Jun 16, 2006 | 08:30 AM
wross996TT's Avatar
36/44 just like the OEM rubber. Of course, you may want to tweak from there as you say. I have no problem with the recommended pressure, but I also do not have OEM suspension or rims.
Old Jun 16, 2006 | 09:28 AM
kiko's Avatar
kiko is infamous around these parts
Wross is 100% correct (as far as I concerned..) I used to run 34/40 on the P-Zeros (and their stiff side walls) but with the PS2's I DEFINATELY run them at 36/44 otherwise it will feel floaty ay high speeds.
Old Jun 16, 2006 | 09:51 AM
tom kerr's Avatar
Above guys as usual are correct. But one thing I would add is if you go to a track event keep them hot at around 40 they really heat up and need to watch or they will be at 55!
Old Jun 16, 2006 | 04:43 PM
ritchieswimwear's Avatar
ritchieswimwear is infamous around these parts
I live in South Florida and have your set up, 36/44
Old Jun 16, 2006 | 05:57 PM
ebaker's Avatar
ebaker is infamous around these parts
I have oversize 235/315 PS2's. The seem to do fine with 31F 34R in everday street use.
Jul 29, 2019 11:13 AM
Peach PTT
New Member Introductions
Sep 3, 2015 12:31 AM
LiquidElephant
Aug 27, 2015 06:17 PM
The Oss
Aug 24, 2015 08:19 PM
murox
Aug 22, 2015 10:32 AM
