K&N Air Filter Install
rspiteri, easy, just remove the 13mm bolt at the rear base, loosen the large intake hose clamp in front of the air box, once the hose clamp has been loosened rotate the entire box counter clock wise until it's almost competely upside down, then slide the box off of the hose. Once the box is removed just loosen all the Philips screws and remove and replace the filter. Make sure to clean all the dirt and dust around the seal before replacing with the new K&N.
I would recommend laying the air filter on a clean bed of shop towels to help wick out the excess oil from the filter
Reinstall in the opposite order.
Thanks a ton!! I was able to complete the whole job in about 15 minutes.
tropicatango
Dec 4, 2015 02:45 PM
