AX22 GPS Antenna
Old Jun 23, 2006 | 01:20 PM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
AX22 GPS Antenna
How and where are you guys mounting your AX22 GPS antenna?
Details please.
Thanks,
Craig
Old Jun 23, 2006 | 01:22 PM
VRAlexander
Guest
Posts: n/a
I vented the sunroof and put the receiver on the center of the roof area...I will snap a picture...give me 2minutes..
Here are the photos...I also mounted the AX-22 in the center of the front window and then used a digital level and made shure the unit was 'square' on flat ground....I also like to calibrate the unit before any runs on flat ground with the engine turned off (the less vibrations the better when calibrating)....
Attachment 35885
Attachment 35886
Attachment 35887
Attachment 35888
Be safe and have fun!!
Old Jun 23, 2006 | 01:46 PM
Jean's Avatar
Jean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond repute
Alex, aren't you overdoing it a little bit? When I said make sure it is level, I did not mean you needed a Harvard degree to check it out!
Old Jun 23, 2006 | 02:05 PM
Ruf-Racer's Avatar
Ruf-Racer has a spectacular aura aboutRuf-Racer has a spectacular aura aboutRuf-Racer has a spectacular aura about
Antenna mounting
Craig,
Generally speaking the GPS antenna will work best if located on the top of the vehicle..assuming you have a metal roof. The metal roof serves as a "ground plane" which effectively increases useable signal strength.
FWIW,I have several GPS antennae roof mounted and I simply snake the coaxial cables thru a small crack in the passenger side window.Yes,I have crimped more than one cable when I had a brain cramp and closed the window to tightly.
Cheers
R
Old Jun 23, 2006 | 03:36 PM
Guy's Avatar
Guy
Guy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant futureGuy has a brilliant future
I mount the GPS on the roof. With the frameless windows, you can shut the door onto the lead if you do it in the right place carefully and it won't crimp. That way there's no wind noise at speed.
Guy
7thsign
Dec 12, 2015 07:43 PM
Glasgo
Nov 30, 2015 02:37 PM
igrip
Sep 24, 2015 11:51 AM
Gusto88
Sep 22, 2015 08:46 AM
