MAF electrical wire
Old Jun 29, 2006 | 11:48 AM
marcog's Avatar
marcog is infamous around these parts
MAF electrical wire
I went to the $tealer, which I rarely do (usually deal with race mechanics), because I was in a rush on my way to the track. I guess they disconnected/reconnected the MAF wires. Now the plastic wiring housing seems a bit abused.
Any chance that my newest MAF failure is due to faulty wiring? I did take it out and cleaned it with contact cleaner and lights are still on; I was curious as to the possibility that the wiring was faulty due to what seems hard pulling? I have the Vflow with oiless filter so can`t be that.
I also noticed that the wiring was indeed hard to pull out of MAF, did you fellow MAF consumers have difficulty in pulling it out?
cheers
marco
Old Jun 29, 2006 | 03:06 PM
rwm514's Avatar
rwm514 is infamous around these partsrwm514 is infamous around these parts
cheers
marco
I not sure exactly what you are describing but Im guessing its the wiring harness that clips to the top of the MAF. They can be a little hard to remove and there is a rubber boot which fits over the clip. Maybe the boot was just messed up/ out of place? I doubt that is the cause. Take a close look at the diode in the MAF. If it is not straight and normal looking than it is probably fried from a voltage spike. Hopefully a new MAF will be available from EVOMS soon. Hope that helps. Rob
BLKMGK
May 31, 2016 04:32 AM
Gtrclive
Sep 18, 2015 12:19 AM
Slider
Sep 16, 2015 12:55 PM
flewis763
Sep 10, 2015 01:08 PM
