Floor Jack Location
Old Jul 8, 2006 | 05:13 PM
KevinTT's Avatar
KevinTT is infamous around these parts
Floor Jack Location
I need to remove a rear wheel. Where is the safest place to jack the car using a floor jack?
Old Jul 8, 2006 | 06:03 PM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
RTFM
The manual has the graphic......all jack points are marked on the lower ABS rockers with the diamond symbol imprint......find rear 6" or so ahead of the wheel arch....then you have to go under car about 6" to hit only the recessed metal surface.....if you do not go under far enough you will catch the rocker, it will pucker, stop & reposition jack.
Old Jul 8, 2006 | 09:44 PM
KevinTT's Avatar
I just wanted to make sure the locations in the manual were OK for a floor jack as I do not have a jack pad.
PelicanParts.com
Aug 28, 2015 12:53 PM
PelicanParts.com
PelicanParts.com
Aug 28, 2015 12:52 PM
PelicanParts.com
BMW Vendor Classifieds
Aug 28, 2015 12:51 PM
JMon
Aug 21, 2015 08:20 AM
