4 point roll bar diy?
Old Jan 14, 2004 | 07:14 AM
sporters78's Avatar
sporters78 is infamous around these parts
Question 4 point roll bar diy?
have a leather covered rollbar on order, should get it right before the meet up in orlando florida.
on a scale of one to ten with ten being the hardest, what do you think is it a do it your self or do i let someone else do it? its only a 4 point roolbar. sometimes i like to do my own work less damage to the car
Old Jan 14, 2004 | 07:59 AM
msindi's Avatar
rockitman has an excellent writeup in the tech section...check renntech.org too
Old Jan 14, 2004 | 08:47 AM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
Technically it's rated a 3, since you need to remove seats, if it's the techequipment rollbar. Only 4 bolts, so can't be too bad right???
There is a physical rating, which I give it an 8....Very demanding getting the bar in place so that you can thread the bolts. Overall, if you do it by yourself, set aside 8 hours. With two people, 4 - 6 hours. The second person is very helpful since they will be able to push on the bar to line it up for the thread points and the other person has two hands available to deal with threading of the bolt. If you do it by yourself, you only have one hand available for each task that must be executed simultaneously....
Old Jan 14, 2004 | 09:14 AM
sporters78's Avatar
Thanks i will try to do it my self, I should not screw it up too badly.......lol
Old Jan 14, 2004 | 09:46 AM
AC 996C2's Avatar
AC 996C2 is infamous around these parts
I installed the Tequipment rollbar in my C2 with the help of a friend. It is a 2-man job just getting the bar in the car. I cannot imagine doing it alone. Rockitman's FAQ in renntech.org is great.
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
Rguy
Apr 12, 2020 11:11 PM
Texas1
Sep 20, 2015 09:12 AM
porsche42
Sep 4, 2015 08:21 AM
AdamNoone
Sep 3, 2015 04:15 PM
