Gauges
Old Jan 16, 2004 | 08:39 PM
  #31
Chordate's Avatar
Chordate is infamous around these parts
You can put them on the A-piller of the drivers side.
Old Jan 17, 2004 | 02:13 AM
  #32
luting_chen's Avatar
luting_chen is infamous around these parts
I wonder if you can implement the Smart Tire Pressure Monitoring into this gauge by dakota.
it'll look great...
Old Jan 17, 2004 | 06:07 AM
  #33
Zippy's Avatar
Originally posted by KPV
Here is the picture I took:
Anyone know who made the CF Gauge console??? Ken????
Old Jan 17, 2004 | 06:24 AM
  #34
PES did the job Zippy~~~~
Old Jan 17, 2004 | 05:40 PM
  #35
cjv's Avatar
cjv
Moderator
Here are pics of my gauge console mounted above the windshield incorporating the lights, IR security eyes and sun roof controls.
Old Jan 17, 2004 | 05:51 PM
  #36
sharkster's Avatar
LOL I remember looking up at that when you started the car thinking we were in the Millenium Falcon So many many lights and gauges hehe. Looked slick.
Old Jan 17, 2004 | 05:57 PM
  #37
cjv's Avatar
cjv
Moderator
"LOL I remember looking up at that when you started the car thinking we were in the Millenium Falcon"
Yeap, I remember telling you not to push the warp button right before you did.
Old Jan 17, 2004 | 06:02 PM
  #38
sharkster's Avatar
Heheh what if you'd had the giggle juice back then as well Warp 7!
Old Jan 19, 2004 | 11:20 AM
  #39
Some new update with Gauges...
I've decided to go with Defi Gauge, which is known to be one of the best on the gauge market I believe. It's really accurate and functional.
it's the system that 02barebones996 suggested, the wiring is easy and clean. (thanx 02barebones996)
But here comes a question, what gauges do I really need on the car?
My Original Plan is
- Boost
- Water Temp
- Oil Temp
- Oil Pressure
- EGT (x2)
I don't know if I can only have 1 EGT. Looking to the design of the engine... is it better to have 2 EGT instead of one? On the PES unit, it has 1 boost, 2 A/F and 2 EGT. I don't think I really need an A/F gauge, so I led it passed.
Here comes a problem, Defi BF serie only come in 60mm gauge, which is almost impossible to squeeze 6 of them in to the center lower console. (I measured it, it might, but it'll look too packed and ugly)
But however when I come to think of it, with Stage 4GTR(750hp)upgrade, I may not need to worry too much about the durability of the car. It's not a 1000hp Supra or etc. And it's reliable.
I then think, should I just have 3 needed Defi Gauages?
New plan
- 1 Boost
- 1 Water Temp
- 1 Oil Temp
- Round Digital Dakota Gauge for tire pressure monitoring.
This way the console will look really clean. But however I still prefer to have 6 gauges b/c then you get to know the condition of your car better.
Or should I just put the Boost Gauge on the left side near A-Pillar (i've seen one of 6-spd board member done this, but he did it for temporary use only, b/c He taped it), and leave the rest 5 in the center lower console?
Or just use 1 EGT gauge? is it ok to just use 1 EGT?
Chad, what do you have on ur car? I don't think I've seen EGT on urs but the Tranny Temp. or A/F? I forgot.... What do you say?
The reason why I want to get gauge is not only b/c I like the look or etc (even though that may be a part of the reason), but when I come to think about it, it's good to know how your car is doing, and also I'm still planning on upgrading my motor once I got used to stage 4gtr program.
Probably within a year or so I'll be upgrading the internal of the engine, and have a new setup that can push the car even further down to the 10sec range. Therefore it's good to have gauges ready by then.
I'm kinda of Frustrated now... so help please?
What do you experts suggest?
Old Jan 19, 2004 | 01:32 PM
  #40
02barebones996's Avatar
02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute
luting.. i would suggest hat you have an a/f gauge bec. it is a more accurate measurement of your fuel mixture.. over the egt 1 i would have both on the car.. if u have the option to have them...
the reason why i have seen two egts are usually one on the primary runner then one on the exhaust near the down pipe afetr the turbo.. the reason for this is to know the temp gauges before air goes in and after the turbo, u supposedly get to have measuremtn of how rich/ lean your car is running due to the temp measuremtn of the egt, i would recomend a good a/f meter bec. it is a better gauge of how your car is performing under boost, below boost or otherwise, u will have a better idea if your car is running lean or rich at different point sin the rpm range.
i hoep this info helps...
i dunno if i still ahev my hook up with defi-gauges i will try to see if i can still get them ... bec. i know of a shop that gives me good deals on parts..
enjoy your upgrades
Old Jan 19, 2004 | 01:57 PM
  #41
Joe thanx ^_^
so are you saying that it's needed to have both A/F and EGT? or is it a better idea to have A/F instead of EGT?
since it sounds like they both look after the same thing...
running rich or lean...
any other gauges i need to know Joe?
thanx for the reply ^___^ hehe... it's really interesting reading and learning all these new things...
Old Jan 19, 2004 | 05:19 PM
  #42
i would reccomend having both a/f and egt...
and the other stuff u listed should be enough gauge monitoring in your beast
Old Jan 19, 2004 | 05:25 PM
  #43
cjv's Avatar
cjv
Moderator
luting_chen,
I have one digital exhaust gauge with six sensors. I can read individual exhaust ports.
Old Jan 19, 2004 | 05:27 PM
  #44
sharkster's Avatar
Originally posted by cjv
luting_chen,
I bet that took a lot of work/wiring! Looked great though
Old Jan 19, 2004 | 05:28 PM
  #45
sharkster's Avatar
PS Question for you, do you mind me asking what the weight of your car was the last time at the scaled? Just wondering... I'm trying to rip off a few other bits and pieces to lighten mine up a bit. Of course I don't have a fancy stereo like yours tho But even the CD changed is being pulled lol...
