P0305 - Cylinder 5 Misfire Detected
Old Sep 3, 2006 | 11:07 AM
Simba's Avatar
Simba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud ofSimba has much to be proud of
Any way you can post a photo of the end of the plug for #5? It'll probably tell you a lot about what's going on.
Old Sep 3, 2006 | 11:26 AM
PorschePhd's Avatar
Umm, sorry Mike. It is the Maf.
You hit the rev limiter recently after that.
Old Sep 3, 2006 | 12:30 PM
Zippy's Avatar
After what? After getting new plugs and coilpacks?
And why is it ALWAYS cylinder #5?
Old Sep 3, 2006 | 03:41 PM
PorschePhd's Avatar
Not sure, give it time and it will show others. BTDT. I just dealt with this.
My question was when did the misfire code come up and when you noticed it had you hit the rev limiter before hand?
Old Sep 3, 2006 | 06:45 PM
Zippy's Avatar
Hitting rev limiter - tough to say. I've been driving my car pretty hard since I picked it up (Friday Aug. 25) after getting the intercoolers in, 3 boost leaks fixed, changing all the plugs and replacing coil packs #1 & #5. It wass running so strong, I have been pushing it to the limit every opportunity I can find. And yes, I have been going out of my way to find those opportunities. I could have tickled the rev limit a few times in the past week. Perhaps the raised RPM limit with the 700 program isn't such a good idea? Is it the hitting of the rev limit, or is it the air flow at the rev limit that is the problem?
After a week of hard driving, it started running a little rough. Noticable only at idle. The code came on yesterday (Friday) when I was idling in my garage while cooling down the turbos.
Old Sep 5, 2006 | 07:23 PM
Zippy's Avatar
Originally Posted by ebaker
When my maf was bad the fuel trims went to neg 17 - 20% in normal driving. This made it run too lean under boost, giving a lean misfire.
Ebaker - Here's a datalog of the short term fuel trims. I extracted the data @ greater than 70% throttle & less than 5% throttle to compair.
Old Sep 5, 2006 | 10:19 PM
Zippy's Avatar
Here is the corresponding O2 sensor readings for the same LOG. During 90%+ throttle, the sensors are fairly equal. At <3% throttle, the sensors are wacked. I was reading the Porsche PET file on P0305 CEL and it indicated the possability of a stuck Vario Cam and suggested doing a test with the cam at high setting and loww setting while monitoring the O2 sensors. If there was a >15% variance during 1 of the tests and >4% variance during the other, it suggested the cause of the P0305 CEL was stuck vario cam. I would be interested in any expert input here (ebaker - you qualify!) Thanks, Mike
[edit] Throttle Position > 3% is actually < 3%
Old Sep 6, 2006 | 12:32 AM
ebaker's Avatar
ebaker is infamous around these parts
I can't tell much from the datalog. When I had the bad MAF I reset the ECU to zero the fuel trims. I went for a casual drive with the fuel trims displayed on the laptop. The short term fuel trims (STFT) started at neg 15% or so. As I drove the ECU compensated (learned) and the long term fuel trims (LTFT) gradually became more negative. The STFT shifted toward zero. After a 12 minute drive the LTFT's were -17%. The negative LTFT would make it too lean at full power above 3000 rpm. At full power over 3000 rpm the O2 sensor logs showed way lean, due to the learned negative LTFT.
If I logged RPM, throttle opening and lamda it showed the lean condition at 3500 rpm full throttle.
Generally speaking, when the MAF goes bad or gets dirty is gives falsely high air flow readings at low loads. The ECU compensates by going negative with first the STFT then later the "learned" LTFT. Under most full throttle conditions at higher RPM the ECU switches to open loop mode. The A/F ratio is controlled by the ECU maps multiplied by the learned too lean LTFT.
This is the way I understand it, I could be wrong.
Old Sep 6, 2006 | 01:26 AM
Change the MAF again and see what happens.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Sep 6, 2006 | 02:17 AM
Zippy's Avatar
Ebaker - thanks for your input. I would give more REP but the box tells me I've hit my quota for you. Thanks.
Old Sep 6, 2006 | 02:21 AM
Zippy's Avatar
Mark - I'm still using the old MAF I bought from you! It's been the longest lasting 1 yet. I'm hoping Todd @ EVO puts together something soon. I'm not compelled to buy another MAF. Do you have anymore used ones lying around?
Old Sep 6, 2006 | 02:41 AM
WOW so its holding up... I don't have anymore MAFs. I hope they put something together too... I just have a feeling that it's more difficult then we all thought. Programming might be a factor as well. just guessing.
9.66
click to view
Old Oct 9, 2006 | 03:50 PM
SMR's Avatar
SMR
SMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the rough
Zippy
Where can i get the same program you are using and what can you log with it,,,?
Old Oct 9, 2006 | 10:53 PM
K24madness's Avatar
K24madness is infamous around these parts
For the brave at heart I have another option to solve the Blown MAF issue. It will require someone that is good at hands on stuff. PM me for details I will be happy to share what I have.
Old Oct 10, 2006 | 10:54 AM
Zippy's Avatar
Originally Posted by SMR
Zippy
I'm using this: http://www.pocketlogger.com/index.php?pid=plobdii
You can log lots of things: timing, O2 sensors, fuel trims, load, RPM, intake temp, etc. The 2 things missing are boost and AFR's. You can clear CEL codes after reading them (a code # and description is given). All you need is an old Palm Pilot, then buy the OBD2 cable and software.
