Battery Maintainer Question
Old Sep 3, 2006 | 07:53 PM
Tpup's Avatar
Tpup is a name known to allTpup is a name known to allTpup is a name known to allTpup is a name known to allTpup is a name known to allTpup is a name known to all
I have a 01 Turbo and the Porsche battery maintainer. The car had some trouble starting today so I started looking for causes. It appears that the battery maintainer comes unplugged from the cigarette lighter. The “nose” of the maintainer has a spring load and slowly pushes the plug out far enough that the red light goes out on the charger.
Does anyone have a solution to this? If not, I’ll go buy another one…
Roy
Old Sep 3, 2006 | 10:17 PM
Westwood's Avatar
Westwood is infamous around these parts
Roy, Check to make sure the side pieces on the plug in are pulled out all the way, otherwise you can use a piece of emery cloth on the side friction pieces to rough them up so they grab the inside of the lighter plug better.
Roger
cnebrask
Oct 3, 2024 08:19 PM
Jul 29, 2019 11:13 AM
DetomasoGTS74
Nov 11, 2015 09:01 AM
DSCOFF
Aug 23, 2015 01:22 PM
