IDEAS? check engine light- very awkward.
Old Sep 10, 2006 | 08:49 PM
Zippy's Avatar
The reason I changed coil packs, as opposed to swapping 1 & 3 for 2 & 4 was to save $$$. It was actually cheaper to change them, I believe ther're about $150 each, than swap/test them and realize they needed replacing anyways. Changing the plugs may do the trick for you. You don't hear much about P0301, despite the numer of guys having to change the plugs.
Old Sep 12, 2006 | 08:23 AM
AIRjordan23's Avatar
AIRjordan23 is infamous around these parts
guys put the stock airbox back on....got check engine light reset. Took the car for a highway spin... from around 3k rpm I floored it in 3rd gear....at 4.5 rpm car as car is pulling, the car feels super rocky n sluggish, but still pulls n boosts 1.1. 1 minute later i floor 4th gear and at 4.5k rpm as I'm wot I get the same non smooth bumpy pull...now the check engine light was flashing at me... as it did a few days ago... the check engine light does not staýjust flashes. I am surethat if I floor it again, the check engine will stay on . so I guess u guys were right. spark plugs. just a question..if I keep driving the car till friday, conservatively...is that ok. am I ruining anything? why does the sluggishness happen at 4.5rpm?
Old Sep 12, 2006 | 12:44 PM
its the plugs. but also inspect the coil packs for cracks.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Sep 12, 2006 | 12:45 PM
wross996TT's Avatar
Flashing CEL is not good. I would not drive the car with this (It is not necessarily aweful, but could be). Get it to the dealer quick. Could be plugs or coil packs (Mark is often right) or bad sensors or vacuum leak...get the codes.
Old Sep 12, 2006 | 01:42 PM
Me_qwkr's Avatar
Me_qwkr is infamous around these parts
Does anyone make aftermarket coilpacks for the car?
Old Sep 13, 2006 | 07:51 AM
mraski thanks i will just change the plugs to the fr6 plugs (already on order) and wil inspect the packs for cracks.
wross, from waht everyone is saying it has to be the plugs....keeping in mind they are stock plugs and im at 21k, + symptoms of bad plugs, i doubt its anything else. Car for the most part, unless driven hard, drives the same.
another thing its a flashing CEL light only if im at WOT in say 4th gear, around 4.5/5k rpm, then the light starts flashing. it then goes off right away as i slow it down. from my experience, if i would keep "testing" the car, it would just trigger the CEL light to -stay on- rather than only blink every now and then when the car is being driven hard around the 5k rpm mark.
Old Sep 18, 2006 | 05:26 PM
Billystang's Avatar
Billystang is infamous around these parts
i think is better to change all coil packs and all spark plugs
thats much better and put the original filter box .
I had evo filter and same problems!
Now i have original with BMC air filter
Car runs great!
Good Luck
Old Sep 18, 2006 | 05:35 PM
guys are the coilpacks under warranty?
i know the sparkplugs arent.
im getting the fr6s any day and will install them myself.
i will check for cracks in the coil packs.
if i still have a check engine light with the same code, do you think coilpacks are under warranty.
tropicatango
Jun 8, 2025 01:00 PM
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
