Rear Camber Adjustment
Old Sep 30, 2006 | 11:57 PM
Zippy's Avatar
Originally Posted by gareeb
I got the Agency Power set from Vivid Racing.
You might even get them for 395.00 if they are still doing the promotion.
http://www.vividracing.com/catalog/p...oducts_id/8370
These look pretty good. I think I'm going to order a set.
Old Oct 1, 2006 | 12:00 AM
Zippy's Avatar
Originally Posted by MUSTGOFAST
Zippy,
I had the same problem as Bart does. That's why I installed the rear links. It allows you to have a lot more adjustment on your rear camber settings. I needed them to reduce my camber to avoid replacing tires every 5kmiles! They do, however, stiffen up the rear end noticeably. They are a quick install too, my mechanic only charged me an 1 1/2 labor.
Thanks man! Seems like a MUST on lowered cars.
Old Oct 1, 2006 | 12:01 AM
Zippy's Avatar
Originally Posted by 9Eleven
TPC put a set on my car. Rear Tow Links. They use them on their race cars. What a difference. The car tracks perfect and feels so much more planted. Bump steer is non existent, feels like it's corning flatter. I paid 450 installed. Money well spent.
Seems like a great value for 450
Old Oct 1, 2006 | 12:15 AM
Zippy's Avatar
Originally Posted by vividracing
Garee,
Thanks Garee. Yes these work on all 996 and 997 models. Give you much more adjustment then stock for camber and toe. They use high grade spherical rod ends and easy to adjust even at the track. If anyone is interested in specs or the product, contact me.
DAn
Are the JIC's worth the extra $400?
Old Oct 1, 2006 | 01:51 PM
oak's Avatar
oak
looking for a set with delrin teflon lining in the spherical ends. I don't want the annoying clunking and rattling after a few miles. are any know of any available? or are these from vivid available with the lining?
Old Oct 2, 2006 | 09:01 PM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Oak......so you've heard these babies start to chatter after a bit?.....kinda like adjustable DLs w/out bushings?
Zippy.........I thought you were looking for more negative camber.....you do understand these arms help with adjustment in the other direction (less negative camber)....that adjustment many loose when they take the suspension down past a point.
Old Oct 2, 2006 | 10:38 PM
Zippy's Avatar
Gregg - yes I understand that. After finally getting an opportunity to take the car out for a really hard drive with the new wheels and tires, I am TRULY amazed at how the car sticks once the rubber is heated up a bit. These are my first set of R compound tires so I don't know how the RA1's 245s & 335s compare to the MPSCs, but holy **** are they impressive. As an indication, I can barely break the tires loose in 1st gear now! Cornering is insane. I'm going to miss the mid/slow speed power on oversteer I used to get with the 225/295 contis. I don't think I need more -C on the rear. I'm going to have to push the car to insane levels to determine under/oversteer characteristics given the level of stick this rubber provides. I'm sure by tweeking the swaybars and ot the coil over settings it can be tuned in without more -C. I just need to do a bit more fender rolling to eliminate the slight rubbing when the car goes over a significant compression. (it's only happened 2 X)
I think I'm definately going to get the rear links to firm things up, but additional "chatter" is the last thing I need. I'm interested in the idea presented by Oak. Is there such a beast?
Old Oct 4, 2006 | 02:38 AM
sharkster's Avatar
that's really the issue with them. They're designed for the track and the street isn't the track and they wear out super-fast...
Old Oct 4, 2006 | 05:26 AM
oak's Avatar
oak
sharky, you can get the spherical ends with a teflon/delrin lining. they are out there. jus don't know why noone makes a set with them. they would be ideal.
Old Sep 24, 2009 | 11:55 PM
GT3 RSR's Avatar
GT3 RSR is infamous around these parts
What is the proper Camber, toe and sway bars adjustment for a track day. I have a GTR RS nad i am wearing TOYOS R888. Could someone help me with this?
Old Sep 24, 2009 | 11:57 PM
GT3 RSR's Avatar
Sorry my car is a GT3 RS 997.
Old Sep 25, 2009 | 06:49 AM
landjet's Avatar
Be careful of too much rear camber, I ate up a set of rears at -2.08. Local race tire guru told me to dial it back to -1.5. I have the adjustable rear control arms also.
Old Sep 28, 2009 | 11:25 PM
GT3 RSR's Avatar
I think for a proper track day the -2.3 +/-5 rear camber is ok. What about the front camber set up. I read some guyes use -3.00 or even -3.25. Have you tested something like that?
If anybody knows i would like to know also about the axle toe they use both front and rear axle.
Jul 29, 2019 11:13 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
The Oss
Aug 24, 2015 08:19 PM
TrackOne
Aug 20, 2015 12:56 PM
