How much can the front and rear tire diameters differ?
Old Feb 3, 2004 | 11:31 PM
Joe Weinstein's Avatar
Hi folks. Is there any Porsche info on how closely the front and
rear tire diameters have to match in order to prevent damage to
the viscous torque transfer unit? It seems that the published specs
of the officially approved tires are not exactly the same. I want this
info for considering what range to stay within if I were to run
other tires and sizes if I were to change wheels etc.
thanks,
Joe
Old Feb 4, 2004 | 01:58 AM
cjv's Avatar
cjv
Moderator
Joe,
I have never seen anything in writing. Sometime back I remember Viken on Rennlist had some information. I believe it was to keep the fronts and rears within 3% of each other. You might look him up and ask the question. When you get the answer, please post it. I have been running five tenths difference for sometime now without any troubles. Remember, the rears wear alot faster than the fronts, so over time the ratio will change from the new tire spec.
Old Feb 4, 2004 | 09:47 PM
cjv's Avatar
cjv
Moderator
Joe,
On the Rennlist forum, one reply refered to a PCA tech by the name of Joel Reiser. When I looked into his response on the PCA tech forum, he quotes 4%. There are a few responses to this issue. If I was to install Michelin Pilot Sport Cups sizes 345's and 265's in the 18" inch wheel I would have a one inch difference which would fall within the 4%. I questioned Rob King, the owner of S Car Go regarding the above sizes and he said no way would it work. He said he has experimented with the Porsche awd and encountered PSM and anti lock brake problems when one half inch difference was exceeded. If he is correct, it is not so much a percentage issue as it is a fixed number issue. What are we to believe?
Old Feb 4, 2004 | 09:48 PM
thanks.
Old Feb 5, 2004 | 04:05 AM
dbelleperc's Avatar
I soon will be a supporting member
dbelleperc is infamous around these parts
You might want to try this web site and punch in different numbers and see what you might be able to run.
http://www.miata.net/garage/tirecalc.html
Old Feb 5, 2004 | 10:10 AM
Exclamation Warning: tire size calculators are bunk!
Hi, and thanks for being helpful, but you just tripped one of my
long-set hot buttons for warning others. The tire specs such as
275-40-17 etc are *only approximate*. Calculators are incapable
of what they hope to do, because of how off those numbers
can be from reality. The only accurate dimension data for a
given tire is from the separately published vendor's spec sheets
for the tire. I have seen two 245-45-16 tires *from the same
manufacturer* differ in diameter by 2%! The only difference
was that the two tires were different model types. ( all season
vs. summer etc)
2lflat4
Nov 18, 2019 05:05 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
gulf gt
Aug 27, 2015 10:27 AM
albert@velosdesignwerks
BMW //M
Aug 22, 2015 07:17 PM
Sterlingc1975
Aug 22, 2015 02:30 PM
