Car amplifier mounting question.
Old Nov 14, 2006 | 01:48 PM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
I want to mount my new amp against the vertical wall in the hood, but am worried about screwing into something important. I assume it is the gas tank behind there. Does anyone know how much depth I have before hitting something. Thanks.
Old Nov 14, 2006 | 03:12 PM
AIRjordan23's Avatar
AIRjordan23 is infamous around these parts
yea...id luv to hear the answer to this one... anyone???
Old Nov 14, 2006 | 05:20 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
I installed a removable amp rack above the spare. I have two amps.
For some reason I cannot post a pic?
Old Nov 14, 2006 | 07:04 PM
Brucem's Avatar
Senior Member
Brucem is a name known to allBrucem is a name known to allBrucem is a name known to allBrucem is a name known to allBrucem is a name known to allBrucem is a name known to all
I got pix of a rack in a TT. I would not drill into the car. get someone to fabricate up a rack for you that mounts up top.
Old Nov 14, 2006 | 07:20 PM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Jags is on it! What you have to do is construct a blank board (MDF) that sits above the wheel (you can carpet it!) then attach the amps to the MDF Board which can easily be removable etc. Do not drill into anything!
Old Nov 14, 2006 | 10:25 PM
Brucem's Avatar
Senior Member
the best way to do it
Old Nov 14, 2006 | 10:53 PM
PorschePhd's Avatar
Why not under the Pass seat? Lots of rook under there.
Old Nov 14, 2006 | 10:55 PM
Brucem's Avatar
Senior Member
not enough room for most amps. and you have to drill holes into the floor to mount it
Old Nov 14, 2006 | 10:59 PM
PorschePhd's Avatar
Actually I mounted my alpine amp under there. You can tag the two sub strips and tap those. It is above the floor. I was able to tab that and run little brackets for a tidy install.
Gezz, how big of an amp do you need
Old Nov 15, 2006 | 12:16 PM
M3CAB's Avatar
Hey BruceM, do you have other pics of the first install? My trunk is setup like that, and am interested in those brackets. Thanks.
Old Nov 15, 2006 | 05:54 PM
Brucem's Avatar
Senior Member
those are the only ones I have. The install was done by www.signatureaudiousa.com located in Scottsdale. quite a few guys from this board go there.
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
Oct 6, 2015 05:20 AM
pwdrhound
Aug 20, 2015 05:54 AM
