GT2 150 KG lighter than 996 TT
Old Dec 4, 2006 | 02:18 AM
Red 9's Avatar
Red 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond repute
Originally Posted by KPG
Ummm... I win. 3760# 01 TT AWD with full fuel, helmet, laptop... and anything else that I keep in the car at the dragstrip or the roadcourse. Just say no to skinny cars Kevin
Makes your cars performance all the more credible. What was that formula for ? HP = ? LLBS
Old Dec 4, 2006 | 02:20 AM
supercup's Avatar
supercup is infamous around these parts
Originally Posted by cab4kw
You must have alot of options on your TT. My stock 2003 TT with heated/memory seats while 4 corner balancing weighed 3471 with 1/2 tank of fuel (without driver of course). The fronts are 671/655 and rear 1082/1063. The owners manuel stated that a manual TT weights 3394.9 lbs without options. With the heavy seats gone (126 lbs savings) and RG5 19s, it now weights 3293 dry, not bad for an AWD with standard battery, subwoofer, and rear seat still in.
My 01 TT had leather everywhere, power heated memory seats, "non" hollow spoke wheels (they were not out when my car was delivered in late 2000), nice upgraded stereo (Reus), carbon shifter & brake handle, alum. door sills. So it had no weight advantages.
Looks like my GT2 is heavier than most as well!
JCM
Old Dec 4, 2006 | 02:36 AM
Divexxtreme's Avatar
A lot of the variation you guys are seeing is due to the scales that are being used. Static truck and car scales (including those at the dragstrip) can be quite inaccurate, especially truck scales that aren't calibrated for weighing lightweight 3-4k lb cars. The most accurate way to get your car's weight is to use professionally calibrated corner-balancing scales.
Old Dec 4, 2006 | 07:01 AM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Originally Posted by Divexxtreme
A lot of the variation you guys are seeing is due to the scales that are being used. Static truck and car scales (including those at the dragstrip) can be quite inaccurate, especially truck scales that aren't calibrated for weighing lightweight 3-4k lb cars.. The most accurate way to get your car's weight is to use professionally calibrated corner-balancing scales.
Wonderful....you mean I can actually weigh MORE than this....Kevin
Old Dec 4, 2006 | 09:18 AM
SMR's Avatar
SMR
SMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the rough
3100 lbs will make for a real fast car when the snow melts Kevin
I hope so, and im have some nice mod to go with the light weight
And the new drifbox is here soon, they have a new model without the drift..
Old Dec 4, 2006 | 03:10 PM
fasteddiett's Avatar
fasteddiett has a spectacular aura aboutfasteddiett has a spectacular aura about
gt2 has little sounddeadening, undercoating etc... ther probably 50 lbs there alone, ceramic brakes , i dont know the difference per wheel but even at 5-8 lbs per that could be another 20-30 lbs... no back seats... all the littel details add up on wieght savings
Old Dec 4, 2006 | 10:12 PM
cab4kw's Avatar
Junior Member
cab4kw is infamous around these parts
Thanks for the info, I guess my car's weight is very accurate since I obtained the weight while corner balancing........who said corner balancing is not useful!!
Old Dec 5, 2006 | 02:00 AM
supercup's Avatar
All weights I posted were taken from calibrated corner balance scales at the race shop when the cars were being set up.
JCM
Old Dec 5, 2006 | 03:28 AM
JCM
A have full leather as well. Any idea why your TT is so heavy, Super?
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
