Pss9 - Can the settings be adjusted easily ?
Old Jan 1, 2007 | 05:52 AM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
On the car with the wheels on, if I say say set them up with 5 but then want 3 for example, probably another one of my ridiculous questions
Old Jan 1, 2007 | 09:23 AM
maxwell's Avatar
maxwell is a jewel in the roughmaxwell is a jewel in the roughmaxwell is a jewel in the rough
its not hard. The rear ones are easy, just pull the carpet thing off the reard decklid and the ***** are right there.
The front ones you need to turn the steering wheel all the way to one side, and then you can reach it. Theres a little rubber cover over the front ***** that you have to pull off to adjust it. Then turn the steering wheel all the way to the other side and repeat. Should take about 5 minutes.
Old Jan 1, 2007 | 10:23 PM
JNRSM3's Avatar
JNRSM3 is a name known to allJNRSM3 is a name known to allJNRSM3 is a name known to allJNRSM3 is a name known to allJNRSM3 is a name known to allJNRSM3 is a name known to all
only problem is that it may be hard to see where you are adjusting the front dampening too. u kinda have to "count" the clicks, assuming you don't raise the front of the car up.
Old Jan 2, 2007 | 01:51 AM
RCH's Avatar
RCH
Thks Guys, what settings do you run yours on please ?
Old Jan 2, 2007 | 02:11 AM
JNRSM3's Avatar
4 up front and 3 in the rear since there is more weight in the back.
Old Jan 2, 2007 | 09:53 AM
maxwell's Avatar
3 up front, 2 in the back.
Old Jan 2, 2007 | 11:09 AM
RCH's Avatar
RCH
tx. Maxwell/JNRSM3 either of you have GT3 rear sway bars if so which setting
Jul 29, 2019 11:13 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
pwdrhound
Aug 23, 2015 07:36 PM
TrackOne
Aug 20, 2015 12:56 PM
Aug 19, 2015 06:35 PM
