who has one of these?
Originally Posted by 03-turbo911
I think someone who had installed it didn't like it and yanked it off. I can't remember the thread or who posted about it.
Stevo, Jean's running a Recardo built Sequential Gearbox and not just a shifter.
Originally Posted by ZAMIRZ
Martin, as I said above, this is simply a "shifter". Not like straight-cut gears, not even close. It's basically a cool toy. No need to rework transmission, you must still use clutch on each and every up and downshift. If you do a search on "autronic" or "autotronic", you should be able to pull up some info on the system.
There was a guy on the board a couple of years ago who had 1 installed - forgot who it was. I think it would be verry useful on the track. I can't tell you how many times I've gone barrelling into a corner and needed to make a shift - while forgeting what gear I was in! Oooof. Nothing like having to look down at the stick while braking hard, trying to heal/toe and concentrating on executing the your line into the corner.
It's very ugly.
It's very ugly.
Now that would be a simple ( I hope) yet great mod, surely it saves time just shifting back and forth for the gears. Yeah it sucks having to still use the clutch for each shift ,but its not really that big of deal.
Martin I knew you would be interested in this,
Bajo
Bajo
Bajo
Bajo
we have it on a an EVo8 at the shop... but that car is used mainly at the track....
2001 996TT 3.6L and stock ECU
