holy road noise batman!
I will end your searching, wheel bearings hand down. Had to replace my drivers side front when i got my car, the noise/whining was UNBEARABLE and got worse as speeds increased! Its not your tires
Could very well be WB's. Try turning your wheel to the left/right when coasting in neutral (use smart judgement where, etc) and see if the noise goes away. If so then your front wheel bearings are shot, inspect the tires as well even if it is your bearings.
Yeah, at 70+mph I also have difficulty talking on my phone, eating french fries, holding my latte-halfdecaf and lighting a cigarette. Oh wait, this thread is about road noise and I don't smoke. Nevermind.
I had P-zeros and a bad front left wheel bearing. My vote goes towards the bad bearing. Do you get any steering wheel vibration?
go-fast, i hear ya. i had the same experience in my 355 and my buddy with his 360...who knows...ill get some PS2s and have the bearings checked out. If that doesnt work ill just get a E63 AMG!
Give me a call, we'll talk.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
illm3 so all these guys are smoking the same thing?
Get the car checked out and report back, so we know if we should get the stuff to smoke from Marty or get it elsewhere.
Originally Posted by BBGT2
Yes and we get it from him.
i'll guarentee it, i had the same thing and tried every solution, it was like hopping into a sealed room after with no noise, night and day diff. !
If possible try to hook up with another owner and put his wheels on your car. I used this approach when I had a slight shimmy that I wanted to see if it was tire/rim and it definately eliminates or determines the problem.
been driving the 911 for about a week now and holy cow is there alot of road noise. Cruising at 70 MPH i can barely carry on a phone conversation...this thing makes my 355 sound quiet! is it just my car or is this typical? Car seems to be louder inside and it is from the outside.
