Tire wear ....
Old Jan 31, 2007 | 12:19 AM
rad's Avatar
rad
rad is infamous around these parts
Tire wear ....
I've noticed that my rear tires wear quite a bit more on the lateral or outside aspect compared to the inner. I've assumed this is probably normal as my prior 911 Carrera did the same thing. Does this mean my alignment is off? I'm running Perrelli PZero Assimetricos (no *** jokes please!) and when I drive the car I drive it hard and corner hard.
Thx
Old Jan 31, 2007 | 12:31 AM
notquitefob's Avatar
notquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud of
if you wear more on the outside, it means you can use a lil more negative camber. you prolly drive around town more and take fast turns = ) exactly how the car is suppose to be used.
for me, i drive 50 miles freeway commute each day, so negative camber causes a lot of inner wear and less use out of my tires : (
PAULUNM
14
May 27, 2016 06:54 AM
manny5
Feb 9, 2016 11:54 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
Nikg
Sep 21, 2015 10:32 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
