Help...Crooked Wing...Pics Inside
Old Feb 5, 2007 | 11:17 AM
roadsterdoc's Avatar
Member
roadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to behold
Try cleaning the post as stated above. Extend the spoiler all the way, with someone lifting the sagging side as you push the dash switch. Clean the posts with WD-40 and wipe dry. Then lubricate with a slicone spray. Wipe off the excess. If that doesn't work, one of your rams has a leak. If the pump motor was bad, it wouldn't move at all, so that is not your problem.
Old Feb 5, 2007 | 11:25 AM
Member
Originally Posted by CSD952
Although the hydraulic rams are known to go bad, it sounds like this is a binding issue maybe due to colder weather (not sure of the temp there) or grit stuck on the post. I would also try the WD40 first.
If one ram is going bad and losing power versus the other they will recede at differing rates causing skew and potential binding problems. Cold weather makes that worse. I am not sure but I think these are 2 way rams meaning power is used for up and down, so the down circuit could be losing power to one ram causing the bind. That could be simple fluid leak at a fitting.
Good luck and let us know how you fix it.
The rams are hydraulic with no direct electrical control. The pump motor is electric and pumps fluid to each ram. It is located between the rams. There is an electronic microswitch on the outside of the right ram. The pump switch reverses polarity to the pump motor in order to raise or lower the rams.
Old Feb 5, 2007 | 12:53 PM
WOODTSTER's Avatar
Mine also happened on very cold day.
I just pushed the manual down button and down it came.
Never happened since.
mK
Old Feb 5, 2007 | 02:06 PM
sechsgang's Avatar
sechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant future
I got that too...It was solved with wd40...but I decided to just get rid of all of it and get a GT2 wing...
Old Feb 5, 2007 | 05:02 PM
jrgatfh's Avatar
Awaiting Email Confirmation
jrgatfh has a spectacular aura aboutjrgatfh has a spectacular aura about
I finally fixed it today , I drove it over to a friend of mines house we looked at it over and over again and realized that the motor and everything was fine and it had to be sumthing else. Sprayed a lil WD-40 on it and let it sit for 5 minutes and viola!!! Good as new!! I'm so happy now I feel alot better thanks for all the advice and suggestions guys, you are the best!!!
I guess when it gets stuck u just need a little lube to slide it right in there haha Have a great day guys and enjoy the superbowl!!!
Old Feb 6, 2007 | 12:40 AM
willcoxmd's Avatar
willcoxmd is infamous around these partswillcoxmd is infamous around these parts
Originally Posted by jrgatfh
I honestly dont think its the motor....Because the wing does go down it just seems to get caught at a certain point. I feel like something is in the way thats y its not moving
Samething happened to mine a few months ago. The dealer said one hydraulic was out and both motors were bad. They replaced everything. my wing is not limp anymore!
Old Feb 6, 2007 | 12:46 AM
Schuepbach's Avatar
Schuepbach is infamous around these parts
spray it down with WD40, make it go up and down a couple times, wipe away excess WD40
Old Feb 6, 2007 | 12:52 AM
Jimbo's Avatar
Jimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud of
We're all glad, including a possible wife/girlfriend, that you can get it up, and keep it up.
Old Feb 6, 2007 | 01:12 AM
mine started a few days ago.,.... today I had to take it to the shop and it got stuck the same way.. I have a light come on too. its 1 degree outside...
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Feb 6, 2007 | 01:15 AM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Same also, but I just disconnected (small wiring mod, no light) and left it in up position, does look better also!
Old Feb 6, 2007 | 01:17 AM
yes I tried but it stays down... like its spring loaded or something....
9.66
click to view
Old Feb 6, 2007 | 01:18 AM
jrgatfh's Avatar
markski
Just lube it up and giv it sum viagra and it'll be fine!!!
Hopefully its not serious on your car and is something like a little WD-40 that'll take care of the job. It just been so cold out lately I'm gonna give the TT a rest for a while I feel bad exposing her to these cruel weather conditions.
BTW your rims are sickkkk I'm sure someone will buy them, and I'm really tempted to take those seats off your hands but I'm so poor lol
Old Feb 6, 2007 | 01:48 AM
is that Martins old car?
The seats are really nice... Im going in a different direction with the car so Im switching to everything thats lightweight... rims too.
9.66
click to view
Old Feb 6, 2007 | 02:39 AM
jrgatfh's Avatar
Yea it's Martin's car I just bought it from him like a month ago, he lives right by me we are good friends now. His new car is insane, and yours is soooo ridiculous. Yea, I've noticed you've been going in a different directions and I cant wait to see the end results its going to be sick....Good luck with everything and I'll let you know about the seats
Old Feb 6, 2007 | 06:44 AM
pilone's Avatar
pilone is just really nicepilone is just really nicepilone is just really nicepilone is just really nicepilone is just really nice
Hey Justin...is that the car iLLM3 sold to you?? Always awesome!
