DIY: Optima battery hold-down bracket
Old Feb 18, 2007 | 08:22 PM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
I saw that in a previous post - nice work. I agree that it looks like it's made by NASA.
Old Feb 18, 2007 | 10:46 PM
silvershark's Avatar
silvershark is infamous around these parts
Originally Posted by Divexxtreme
Not sure where that rumor came from. I've been using a PC680 for over a year with no issues.
What I was told by Chris @ TurboKraft....the PC680 should not be used
as you would an every day driver battery.
Old Feb 19, 2007 | 11:55 AM
zdr2k's Avatar
zdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud of
+1.
i agree with that. My choice was an optima.
Old Feb 19, 2007 | 01:21 PM
JayM's Avatar
JayM is infamous around these parts
I went with an even easier solution for my Yellow-Top. I positioned it where I wanted it on the battery tray and marked that spot, then took the tray out, marked the position of the four Optima mounting points, drilled four matching holes in the battery tray, and bolted the Optima to the tray. Then I bolted the tray back into the car and voila.
I was able to use the original cables as well.
Old Feb 19, 2007 | 06:48 PM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
The thickness of the plastic at the 4 drilling points is quite thin. I am concerned about the real staying power in a shunt. There are some fuel tanks up there somewhere, but I don't know the exact positioning. I suppose it would pass tech if the inspector didn't know how thin the plastic really is on those 4 corners, or maybe it's really not an issue with 4 bolts.
Has anyone had any experience with tech inspections having that type of installation? Not being critical---just seeking information as to the best way to make the battery substitution as safe as possible. Did you use bolts and nuts with washers?
Old Feb 19, 2007 | 07:00 PM
jimmer23's Avatar
My Red Top didn't even have any extra plastic to bolt it down to the tray with (it is "shaped" at the bottom). I think this way is infinitely more secure...
Old Feb 19, 2007 | 07:44 PM
Al Norton's Avatar
Jay M,
Mine must be a little different. Can you post pictures of the installation?
Old Feb 19, 2007 | 08:36 PM
tom kerr's Avatar
It does not have the storage power of a full size battery. It can be used as a "daily driver" ie to and from work but it really needs to be put on a charger at night. It is really meant to be a "racing or track" use battery. So really why would you use it in a car that is being used as a daily driver? No reason to risk the problems.
I do have another trick that I use with this battery. When I travel I keep a battery pack with me. I use it to charge the battery and to have to jump in case of emergencies.
In the last 18 months with the car I have never had to jump start the car.
Just my experience your result may vary (keep in mind I live in Florida) this certainly is not a cold weather battery.
Old Feb 19, 2007 | 10:18 PM
JayM's Avatar
Now I am confused-is your battery tray plastic? Mine (a 2002) is metal, so I have no worries about staying power. Or are you referring to the plastic Optima case? There are four notches near the four corners of the battery that are the designed mounting points, and the plastic there is probably half an inch thick. I have a pretty hard time thinking that battery is going anywhere. BTW, I did exactly what you said-used short carriage bolts with washers to secure each corner. I will try to take some pictures tomorrow, but once the tray is bolted in it is pretty hard to see anything.
Old Feb 20, 2007 | 07:36 AM
jimmer23's Avatar
Why would you ever do that? Have you ever seen a factory battery held down in that manner? What on earth makes you think that is safe, or the battery case is made to withstand those kind of shear forces acting upon it at four corners? I know I could never trust a battery held in like that at high cornering speeds.
My battery didn't even have any extra plastic to do this, but I still think it'd be an unbelievably bad idea to do so...
Old Feb 20, 2007 | 11:16 AM
Al Norton's Avatar
Jay, I used the original tray and built a modified steel hold-down that follows the curvature of the battery and grabs it fore and aft at the edges. I have lined the metal part that touches the battery with a split piece of small diameter fuel line tubing to prevent any abrasion. I then placed the original hold-down clamp over the modified piece of 3/32" steel. I have the safety-wired Lexan wedge in the front of the battery so as to push it full aft to engage the factory designed lip for security. I opted out of the drill and bolt method you chose as I felt I could secure the battery better in this fashion. My battery (model 35) does not have the notches of which you speak.
Old Feb 20, 2007 | 01:20 PM
JayM's Avatar
Hi Al,
Your approach is superior to what I did, no question. But I still don't think mine is going anywhere. BTW, mine doesn't have the notches I mentioned either (hey, it was late and the memory fogs after a few glasses of Pinot), but rather four rectangular holes. The "standard" Renntech mounting approach (AFAIK) is to make a mounting bracket, bolt the battery to the mounting bracket, then attach the mounting bracket to the battery tray using the OEM hold-down. This picture below is from Oggie's post there, and again AFAIK the four bolts (#10s, aircraft quality btw) are the only things keeping the battery from flying around in the event of a crash. What I have done is to eliminate the mounting bracket, because with the yellow top I would not have had enough clearance to use my existing battery cables (at the time I purchased it, there were no reverse polarity yellow-tops).
Like I said, you guys have some incredible installations, no question. But some of us are devotees of the wise woman who said:
"I don't think necessity is the mother of invention - invention, in my opinion, arises directly from idleness, possibly also from laziness. To save oneself unnecessary trouble".
The lazy part fits for sure; you think I am seriously at risk here?
Old Feb 20, 2007 | 06:17 PM
Al Norton's Avatar
Hi Al,
I love your quote about necessity....
Seriously at risk? Who the hell am I to judge this---I'm a NU-BE to the world of Porsche mods. Looking to the right and left of each of those bolt placements I see an inverved square-type channel. Looks like that wouldn't give the bolt attachments a lot of staying power in a heavy G-force crash. At the top of the inverted square, the plastic looks to be very thin, and any right angle is an automatic stress riser, or potential break-away point, as best I remember from my 2-decade-old knowledge. Maybe the cables would keep it in place; I really don't know. Perhaps there are shunt survivors with this arrangement who can chime in.
Old Feb 21, 2007 | 11:37 PM
Originally Posted by tom kerr
It is fine if you charge every night. I also keep it on the charger at the track. It works fine if you are careful and the weight savings cant be beat.
you can get the brackets from rennline.com
Tom, Did you drill the mounting holes shown in the pics?
Old Jan 20, 2010 | 09:06 AM
PrecisionPorsch's Avatar
PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !
Originally Posted by jimmer23
Hey all, thought I'd put together a quick post on how to make your own modification to the stock battery tray which will make the Optima that many of us use more secure, and a factory-looking install.
Here's what you will need:
A 28" length of 2" wide, 1/8" thick aluminum stock
A 2" long M8 bolt with 2 washers, 2 nuts, and 2 lockwashers
A gallon (or less) of Plasti-Dip or equivalent
STEP 1: Cut stock to length, then bend in the following dimensions:
top = 10"
sides = 7"
left side lower tab = 2.5"
right side lower tab = 1.5"
Use these pictures as a rough guide:
Left side, drill a oblong hole about 1" long and 1/2" wide closer to the terminal side of the stock and starting 1/2" from where you made your bend.
Right side drill a round hole 1/2" diameter right after the bend in the same position as the other side.
STEP 2: Coat in Plasti-Dip. This creates a rubber coating which is useful to have when you're mounting something so close to the terminals. 3 coats was enough for me and didn't cause any problems with the resize of the dimensions. Be sure to sand the surface a bit rough first before coating so it sticks, then let dry for a few hours between coats for a uniform finish.
Coating
Finished product
STEP 3: Remove the stock battery tray. On the right side there's a convenient non-threaded hole. This is where you want to mount the stud with the M8 bolt. Put the bolt through the underside and secure with the nut and lockwasher. There's a gap under and over the tray - almost like they were asking for precisely this. There will still be sufficient thread to put another nut on top when you mount the bracket.
STEP 4: Disconnect the battery, put the bracket on top, and secure on each side. The stock bolt will fit in a new hole on the factory tray which is close to the new battery location.
That's it. It was pretty easy, and truly looks like a factory job. There is no chance that this battery will go anywhere now, and I feel more secure throwing the car around corners now. The other options just weren't working for me.
I hope this helps more people use these great batteries that may have previously been put off by the lack of options as far as mounting is involved. Anyone has any questions, feel free to ask. I have some stock left, and would even be glad to make a couple more as I have some stock and a LOT of this Plasti-Dip stuff left.
Regards
Jimmer.
Which optima did you get? I went to Sam's club and I couldn't find the right one for the turbo in the book they had. Thanks
Edwin
