stock rotors are glazed. What does that mean.
If your going to be driving mostly on the street, the OE pads are the best bet. All other pads are just going to try to emulate the OE standards. Racing pads on the street are far too abrasive and will not stop well. Street pads are manageable on the track, they will just wear and fade more quickly. You can deal with the attributes of the street pads on the track but obviously not the race pads on the street.
Remember, Porsche has the best stock brakes in the industry, they are always being emulated. The only way to get more stopping power is to get larger brakes, it’s just physics. Big brake kits allow you to push your car much further at the track, even while using a pre street pad. So if you want to stop noticeably quicker you have to speed some decent cash. Messing around with non OEM products will only cause problems.
If you encounter the glazing problem again you just need to re-bed the brakes in order to transfer pad material to the rotor. They glazed over in the first place because the daily driving ate all of the pad material off.
19000rpm you should be a novelist! (but you do have some font issues)
I think we're mostly on the same page, but...
Totally agree - but - you do have to get brakes *hot* to bed in. A progressive heating with some ramp-up - then some stops to actually transfer material, then some moderate stops to clean off excess and cool down. Follow the Pagid proceedure, as their pads are the most susceptible to bedding issues.
Please...
Ahh, no. You really should think about what's happening at the Metallurgical level - The crystalline structure of the iron or steel is disrupted due to heat causing the surface *and moderate penetration depths* to be affected.
You really do have to either machine this off (getting well below this area) or abrade this off using some means.
Just re-bedding the brakes onto glazed surface won't get even or effective pad transfer to the rotors. You have to start with a moderately good surface to bed. Agreed?
Fine - just ramp up the heat like I said. Agreed.
AIRjordan23 tracks. He was using stock pads and then mintex. The cause IMHO was overheating the rotors via brake technique and some surface heat treating from the orig. stock pad incident.
If you're gonna track, then you need to swap out pads that are going to handle the extended heat range without causing rotor damage.
As far as "No one does this." using an track pad as an abrasive.. Well I certainly do, and all my track buddies do. We all get some pad transfer sometimes that causes "shudder", and if you have the Hawk Blues (or other high abrasive pad) sitting around, why not use 'em. Certainly everone trying to find a compromise pad for the track and street will not succeed. You need to swap out pads before an event. You either get squeeel on the street and poor cold performance with a track pad on the street, or really overcook the brake system and do damage to the rotors with street pads on the track.
As far a Stoptech/Porsche recommending pad/rotor conformability - as a general rule - yes. You have to know a little about what is happening, and there is a bit of judgement as to how much to scrub the rotor to get all that old pad material off before you can bed the new pad to the rotor. They are going to err on the side of "lawyer safety" and just not go down that route. If you do know a bit, have some experience and do some observation, you can feel when you've removed the old bedding and safely rebed new pads.
Again... Please...
Originally Posted by 19000rpm
Bedding in new brakes, is something that does have to be done. With new rotors it should be done very lightly and not at high speed with a lot of cool down in between to start off with. It doesn’t matter what type of car, minivan or Ferrari, if you don’t know how to get pad transfer to the rotor surface properly, you will just end up causing squeaking, juddering, and excessive runout (warped). That’s why if you ask any dealer, mechanic, engineer they will say take it easy on the new parts until they get a few heat cycles on them.
Changing between pad compounds to get rid of glazing? This shows how much experience you have.
If he was going to keep the brakes he has on, and just get rid of the glazing, all you have to do is re-bed the brakes.
Casual driving on broken in brakes is what causes glazing. Normal street driving relies mainly on the abrasive properties of the brakes to stop the car thus un-beading the brakes by removing the pad material that was transferred to the rotor, via abrasion. I’m not saying you have to baby the brakes all the time, just until the new metal has been through enough heat cycles to have warping not be a issue.
He seems to rely on the dealer to do his work. If he wanted to change pads when getting new rotors, or to deglaze the brakes according to your technique they would change him twice the labor and laugh. " I was a tech for a good period of my life, never once has anyone asked me to reuse old pads to bed in new brakes, or install race pads to act as abrasive. I have however had people come back the next day and say they tested their brakes a few times and now they get a shudder. Telling a customer to go out and bed in new brakes, or to drive normally on them is inviting in trouble. Taking it easy will slowly introduce the pads and rotors to heat and still transfer pad material to the rotor face. Ask a shop how many times they have had people warp and ruin new rotors. That’s the most expensive part to replace as well, and with all euro cars you will replace rotors and not resurface them. This is a generalization, but most of them use softer rotor material as opposed to the majority of domestics using harder metal.
Using different compounds is probably what caused his original problem.
Don’t harass me about this info, it is what ASE course, and tech schools will teach you. There are far to many experts on 6speed, but it’s easy to see which ones have actual experience.
Didn’t know you tracked your car. There are just different practicalities for people who don’t work on their own cars. Having to redo the work you did just the other day because a customer was not told something properly is no fun. I’m just used to saying its safer to go slow on new brakes. There have been some people that ruin an hour of work in a few seconds, then bring the car back and blame it on the installer.
I personally see nothing wrong with doing it another way, it’s just something I have never had a customer ask for. Having two sets of brakes for the road and the track isn’t in everyone’s budget or skill set either. I guess that’s my favorite excuse to have a couple cars. PCCB, and carbon helped eliminate the need for both. This makes the option cost for the ceramics more reasonable to those who question the cost. You get a great street and track break all in one.
When you are starting out at DE's - stock is fine (although a good low hydroscopic higher temp range brake fluid flush is a *really good idea*)
But as you progress through the ranks, and the limits of grip, you need to diverge into purpose built equipement - i.e. tires (R-compond), brakes (track pads), etc.
Then comes the suspension.... Just the slipery slope.
BTW, nobody in their right mind tracks PCCB's! Failures and cost.
Believe it or not I’ve scene it done very successfully, guess they weren’t in their head. Lap time was good though. The 2nd gen doesn’t have all the problems like the early ones. MovIt is even going to produce a full racing version that should be very similar to carbon/carbon. I guess well see how those work out.
I am some what confused... Both 19000rpm and Dietz make valid points.
I have done numerous sport brake upgrades on everything from Lexus to Mitsubishi cars. On the last set of Brembo's installed with new pads ,SS brake
lines and ATE blue fluid. I took it very easy in town, stop light to stop light.
Anticipating stops as if braking on ice, easy pumping motion using 2.5X-3.5X
the distance of a normal stop. But per Brembo instructions, I got on the highway and after reaching a speed of 75-80mph, checking my rear view mirror of any vehicles behind me. I put the pedal very aggressively to the brakes as if an emergency stop... down to 35-40mph. Checked the second hand on my watch for reference.(noted time) accelerated back up to highway speed at a regular rate. Waited at least 45 seconds (usually 60 seconds) to allow for cooling. Then went thru the proceedure of aggresive braking 75>35, then cool down time. I would repeat this procedure 3 times, then allow 2-3min cooling and do it 1-2 more times. I have had great sucess in brake grip, using this method with even cheaper after market upgrades for passenger cars.
Now, I have zero experience with the track cars, however I have a brake job planned for the 996TT with SS lines and fluid change with new pads on stock rotors. I plan to go to Hallet (W of Tulsa, OK) this year for some PCA training and some spirited (hard) driving. I don't want to cook my brakes...
as I have heard of guys doing with such a weekend outing at the track.
What should I use... as far as pads for the Sat/Sun day at the track? Remeber the rest of the time (95%) I am driving aggressive street driving.
Ahh, I hesitate to recommend anything because experience and style/preference is so variable.
That said, and the above disclaimer that there is no compromise pad, I used the Ferodo 2500 series as a dual use.
http://www.raceshopper.com/ferodo_compounds.shtml
For a full track pad that still is streetable, Pagid Yellow RS-29 (or RS-19 if you can't find the 29's) Orange 4-4 if you can stand the pig-like squeel (it's really bad - really)
http://www.braketechnology.com/racecharacteristics.html
although Pagids are finicky to bed in. Follow this to the letter.
http://www.braketechnology.com/brakepadbedding.html
Some say Pagid's are expensive - they are. Pagid's are temperamental to break in and bed - they are. But they are worth every penny. They last.
Jul 29, 2019 11:13 AM
LiquidElephant
Aug 27, 2015 06:17 PM
